Ok so not really sure what happen but everything was fine until last night. I was in the middle of a print and messing with the computer when a video card error popped up and the computer froze. After a minute of the screen flashing on and off the repetier host was not responding and the print stopped. Was I reset the computer and the printer I retried printing the file it started off fine so I went to bed woke up this morning with a bout one inch of the file printed a inch of mess and then nothing above that and the extruded was still making its passes about a four inches above that. So I removed the extruded gave it a good cleaning and reset the bed started the print again this time it would print but it was skipping. So I reset it and it got worse. Every time I kill the print and try it the issue got to the point of nothing coming out. So I cleaned it again tried different filiment started the prin. The first layer printed then started skipping again then nothing. When I lightly place my fingers on the filiment during a print i can feel it jog up and down. I thought the filiment was jamming so I clicked on load filiment just to see what happens it extruded out just fine. Try the print and nothing comes out and the filiment jogs up and down again. I am at a total loss right now the print worked great last night and was almost done with out a single issue and now it won't print at all.
Note: abs 1.75 filiment, repetier host .92.10 hack de vinci 1.0, the idler wheel was a bit loose so I shimmed it and tighted it back up,
