Comandos escritos en Pronterface June 26, 2014 01:24AM |
Re: Comandos escritos en Pronterface June 26, 2014 08:27PM |
Re: Comandos escritos en Pronterface June 26, 2014 11:47PM |
Re: Comandos escritos en Pronterface June 27, 2014 12:44AM |
Re: Comandos escritos en Pronterface June 27, 2014 12:57AM |
G0 - > G1 G1 - Coordinated Movement X Y Z E G2 - CW ARC G3 - CCW ARC G4 - Dwell S or P G10 - retract filament according to settings of M207 G11 - retract recover filament according to settings of M208 G28 - Home all Axis G90 - Use Absolute Coordinates G91 - Use Relative Coordinates G92 - Set current position to cordinates given RepRap M Codes M0 - Unconditional stop - Wait for user to press a button on the LCD (Only if ULTRA_LCD is enabled) M1 - Same as M0 M104 - Set extruder target temp M105 - Read current temp M106 - Fan on M107 - Fan off M109 - Wait for extruder current temp to reach target temp. M114 - Display current position Custom M Codes M17 - Enable/Power all stepper motors M18 - Disable all stepper motors; same as M84 M20 - List SD card M21 - Init SD card M22 - Release SD card M23 - Select SD file (M23 filename.g) M24 - Start/resume SD print M25 - Pause SD print M26 - Set SD position in bytes (M26 S12345) M27 - Report SD print status M28 - Start SD write (M28 filename.g) M29 - Stop SD write M30 - Delete file from SD (M30 filename.g) M31 - Output time since last M109 or SD card start to serial M42 - Change pin status via gcode Use M42 Px Sy to set pin x to value y, when omitting Px the onboard led will be used. M80 - Turn on Power Supply M81 - Turn off Power Supply M82 - Set E codes absolute (default) M83 - Set E codes relative while in Absolute Coordinates (G90) mode M84 - Disable steppers until next move, or use S to specify an inactivity timeout, after which the steppers will be disabled. S0 to disable the timeout. M85 - Set inactivity shutdown timer with parameter S. To disable set zero (default) M92 - Set axis_steps_per_unit - same syntax as G92 M114 - Output current position to serial port M115 - Capabilities string M117 - display message M119 - Output Endstop status to serial port M126 - Solenoid Air Valve Open (BariCUDA support by jmil) M127 - Solenoid Air Valve Closed (BariCUDA vent to atmospheric pressure by jmil) M128 - EtoP Open (BariCUDA EtoP = electricity to air pressure transducer by jmil) M129 - EtoP Closed (BariCUDA EtoP = electricity to air pressure transducer by jmil) M140 - Set bed target temp M190 - Wait for bed current temp to reach target temp. M200 - Set filament diameter M201 - Set max acceleration in units/s^2 for print moves (M201 X1000 Y1000) M202 - Set max acceleration in units/s^2 for travel moves (M202 X1000 Y1000) Unused in Marlin!! M203 - Set maximum feedrate that your machine can sustain (M203 X200 Y200 Z300 E10000) in mm/sec M204 - Set default acceleration: S normal moves T filament only moves (M204 S3000 T7000) im mm/sec^2 also sets minimum segment time in ms (B20000) to prevent buffer underruns and M20 minimum feedrate M205 - advanced settings: minimum travel speed S=while printing T=travel only, B=minimum segment time X= maximum xy jerk, Z=maximum Z jerk, E=maximum E jerk M206 - set additional homeing offset M207 - set retract length S[positive mm] F[feedrate mm/sec] Z[additional zlift/hop] M208 - set recover=unretract length S[positive mm surplus to the M207 S*] F[feedrate mm/sec] M209 - S enable automatic retract detect if the slicer did not support G10/11: every normal extrude-only move will be classified as retract depending on the direction. M218 - set hotend offset (in mm): T X Y M220 S- set speed factor override percentage M221 S- set extrude factor override percentage M240 - Trigger a camera to take a photograph M280 - Position an RC Servo P S, ommit S to report back current angle M300 - Play beepsound S P M301 - Set PID parameters P I and D M302 - Allow cold extrudes M303 - PID relay autotune S sets the target temperature. (default target temperature = 150C) M304 - Set bed PID parameters P I and D M400 - Finish all moves M500 - stores paramters in EEPROM M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily). M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to. M503 - print the current settings (from memory not from eeprom) M540 - Use S[0|1] to enable or disable the stop SD card print on endstop hit (requires ABORT_ON_ENDSTOP_HIT_FEATURE_ENABLED) M600 - Pause for filament change X[pos] Y[pos] Z[relative lift] E[initial retract] L[later retract distance for removal] M907 - Set digital trimpot motor current using axis codes. M908 - Control digital trimpot directly. M350 - Set microstepping mode. M351 - Toggle MS1 MS2 pins directly. M928 - Start SD logging (M928 filename.g) - ended by M29 M999 - Restart after being stopped by error
Re: Comandos escritos en Pronterface June 27, 2014 01:59AM |
Re: Comandos escritos en Pronterface June 27, 2014 02:43AM |
Re: Comandos escritos en Pronterface June 27, 2014 03:07AM |
Re: Comandos escritos en Pronterface June 27, 2014 09:08AM |
manuel19941
Aca estan:
El M106, el que prende el cooler, lo podes usar junto con SXXX, donde XXX es la velocidad de queres, desde aproximadamente 50, no me acuerdo bien, menos no va a girar el fan, hasta 225.
Ejemplo para usar el fan a las maximas rpms seris "M106 S225"
Saludos!
