Welcome!
Log In
Create A New Profile
Home
Machines Organized by Name
Tantillus
> Topic
Attaching gears to 4mm shafts
Posted by
goopyplastic
Forum List
Message List
New Topic
goopyplastic
February 01, 2013 02:04PM
Since the 4mm shafts don't have flats like the 5mm shafts, do we need to modify them by putting a flat on them or will they work fine being round?
Reply
Sublime
Re: Attaching gears to 4mm shafts
February 01, 2013 04:02PM
Flats always help to reduce the chance of slipping so they are always a good idea. Be sure to at least put a flat on the extruder motor.
FFF Settings Calculator
Gcode post processors
Geometric Object Deposition Tool Blog
Tantillus.org
Mini Printable Lathe
How NOT to install a Pololu driver
Reply
james glanville
February 02, 2013 03:24PM
Another option instead of filing a flat, is to add some superglue, that way you'll get much less of a tendency for the gear to slip on the shaft. I ended up having to do that after my screws eventually came loose.
Reply
pokey9000
February 06, 2013 08:58PM
I can confirm this, especially for the extruder. 90% of my initial troubles with Tantillus were due to slippage.
Reply
Newer Topic
Older Topic
Print View
RSS
