LM8UU + LM8SUU vs 2x LM8UU ?
July 26, 2013 09:21PM
I've got a bunch of LM8UUs sitting here on my desk but the LM8SUUs are slowwwwly shipping from China. Is there any reason I couldn't just use 2 LM8UUs?
Re: LM8UU + LM8SUU vs 2x LM8UU ?
July 26, 2013 09:33PM
Two LM8UUs are too long for the carriage. You would lose 7 millimeters on X and Y axis.
July 27, 2013 12:27AM
I'm using 2 LM8UU's on may carriage right now with zero problems (you do loose some print space). My actual build area is only 95x95 but since I only use the tantillus for very small intricate parts it suits me just fine.
July 27, 2013 12:29AM
Oh that's weird... These are labeled LM8UU but they are 17mm long.
July 27, 2013 02:05PM
> they are 17mm long.
Some places that sell linear bearings sell the short ones as the normal size. That is actually how I came across the short ones in the first place.
There should be no problem using all short ones in the carriage and they should also work on the Z stage but may require a little glue to ensure they do not slip out of place.
