Z wobble hack - printed part January 04, 2014 12:43AM |
Re: Z wobble hack - printed part January 04, 2014 05:44PM |
Re: Z wobble hack - printed part January 04, 2014 07:10PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Z wobble hack - printed part January 04, 2014 10:24PM |
Re: Z wobble hack - printed part January 05, 2014 12:24AM |
Re: Z wobble hack - printed part January 06, 2014 10:24AM |
Re: Z wobble hack - printed part January 06, 2014 02:19PM |
wingnut
Interesting stuff. I'm wondering now about just ditching the threaded rod and going with a cable driven Z. I hate the idea of loosing resolution in Z though.. Anyone consider gearing the cable Z down with some belt driven gears?
Robonz, can Is that some kind of cable tensioner inside your XY end? Something like that is top on my list of upgrades.
Re: Z wobble hack - printed part January 06, 2014 02:20PM |
Robonz
Here is a side by side comparison of a challenging print that is 100mm tall. You can see the banding on the back of head is pretty much gone.
Re: Z wobble hack - printed part January 06, 2014 07:13PM |
Re: Z wobble hack - printed part January 06, 2014 08:47PM |
Robonz
I would also prefer a belt to a string for the lift as servicing is less fidely.
Robonz
Talking about belts and pulleys, anyone tried replacing the gears in the extruder with a belt stage? I still have some more pulleys and belts lying around.
Re: Z wobble hack - printed part January 07, 2014 10:46AM |
Robonz
Re: Z wobble hack - printed part January 07, 2014 11:45AM |
wingnut
Robonz
I'm actually working on that now. I considered modifying the original extruder for belt drive but decided on something completely different. I'm attempting something similar to what the ultimaker uses with the stepper motor and extruder mounted up high behind the machine. This will have the added benefit of a considerably shorter bowden tube. I have the extruder body printed. Now I'm working on printing some GT2 pulleys. I already printed a set but darned if I can't find a local source for the M3 keeper nut that the pulley was designed for. I will print a new set of pulleys and hob the new bolt tonight.
Re: Z wobble hack - printed part January 07, 2014 01:54PM |
