Kisslicer January 11, 2014 11:23PM |
Re: Kisslicer January 11, 2014 11:45PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Kisslicer January 12, 2014 02:48AM |
Re: Kisslicer January 13, 2014 12:11PM |
Sublime
No there is no way of making the skirt any more than 1. But you could add something to the start code. The easiest way to figure out the correct code would be to make a large cube the size of your bed and slice it with no infill, 0 skin, and 1 perimeter loop (or more if you think it needs it). Then open the gcode file and copy the first layer code to your start gcode (prefix). This will draw a square the size of the bed/cube around the outside before every print.
The developer of Kisslicer has been missing since September 30th and the forum has received more than 175,000 spams in the last month.
Re: Kisslicer January 13, 2014 12:12PM |
Robonz
In Kisslicer Ptr Gcode
in Tab Prefix
I have this and more. It is work in progress but I find I get pretty much 100% prints to start good doing this.
;move down first so dont drag accross clean table
G1 Z5
; move x,y to front middle of table and set feed rate to 6000 mm/min
G1 X50 Y100 F6000
; move to origin - home z axis
G28 Z0.0
;while at origin add bed offset - nozzle is too close to the bed after homing -n
G92 Z-0.2
;move down 40 so tip is easy to clean
G1 Z40
; wait for extruder to get to temperature SXXX
M109 S200
;extrude waste before printing
G1 E3
;wait (Pxxx mS) for extruding to complete etc
G4 P5000
Re: Kisslicer January 16, 2014 11:31AM |
Re: Kisslicer January 16, 2014 10:42PM |
Re: Kisslicer January 17, 2014 04:47PM |
Re: Kisslicer January 20, 2014 04:01PM |
Re: Kisslicer January 20, 2014 04:22PM |
Re: Kisslicer January 22, 2014 12:47PM |
