A new design of the tantillus lasercut case August 13, 2014 12:08PM |
Re: A new design of the tantillus lasercut case August 16, 2014 10:18AM |
Re: A new design of the tantillus lasercut case August 17, 2014 04:59AM |
Re: A new design of the tantillus lasercut case August 17, 2014 06:23AM |
leonal
No one interest with this version ? it is much more easy to build and it does not need any printed corners.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: A new design of the tantillus lasercut case August 26, 2014 10:47AM |
Re: A new design of the tantillus lasercut case August 26, 2014 11:26AM |
Traumflug
leonal
It's no longer a Tantillus, then, right? There are many sheet-box designs already. I always considered the full printability to be the key feature.
Re: A new design of the tantillus lasercut case August 26, 2014 11:27AM |
Re: A new design of the tantillus lasercut case August 29, 2014 11:03PM |
Re: A new design of the tantillus lasercut case September 01, 2014 10:20AM |
cns1
Sorry to point this out but I'm afraid that it won't be easier to assemble than the regular acrylic case model. The hardest step in reguard to assembley is getting the cables on and tensioned. Everyone seems to agree that the printed version is more challenging than the acrylic case because of the lip on the top of the case. The lip on the top of your case appears to block acess to the cables worse than the printed version which will make it tough to get the cables on.
Also, if you want to get everyone excited about a redesigned acrylic case, then make it bigger and redesign the Z axis to accept a standard 8"x8" reprap style heated bed, and glass. Oh, and don't use a lead screw, belt Z would be fine, dual cable Z, better.
Re: A new design of the tantillus lasercut case September 10, 2014 10:59AM |
Re: A new design of the tantillus lasercut case September 25, 2014 11:52AM |
Re: A new design of the tantillus lasercut case September 29, 2014 02:16AM |
Re: A new design of the tantillus lasercut case October 19, 2014 07:45PM |
Re: A new design of the tantillus lasercut case November 06, 2014 06:51AM |
Re: A new design of the tantillus lasercut case November 08, 2014 10:34AM |
Re: A new design of the tantillus lasercut case November 08, 2014 10:40AM |
ledaero
I have a CNC router, but AFAIK, there isn't a laser cutter in the entire country (I have the first and - so far - only CNC router).
Do you think it would cut fine on a router?
I have been wanting a Tantalus-style printer for ages...
Re: A new design of the tantillus lasercut case November 10, 2014 11:06AM |
Re: A new design of the tantillus lasercut case January 27, 2015 11:23PM |
