Mouting FoldaRap 2.5 - heeeeelp plz December 18, 2016 06:46AM |
Re: Mouting FoldaRap 2.5 - heeeeelp plz December 22, 2016 12:25PM |
Re: Mouting FoldaRap 2.5 - heeeeelp plz December 27, 2016 08:38AM |
Re: Mouting FoldaRap 2.5 - heeeeelp plz December 27, 2016 12:11PM |
Re: Mouting FoldaRap 2.5 - heeeeelp plz December 28, 2016 03:14PM |
FA-MAS
If you've got a switch that has a lever on it for Z, remove the lever, they flex and can introduce inconsistent results.
Also make sure the switch is firmly mounted, of course if it moves when it's pressed, it will give inconsistent results.
Re: Mouting FoldaRap 2.5 - heeeeelp plz December 28, 2016 05:59PM |
Re: Mouting FoldaRap 2.5 - heeeeelp plz December 29, 2016 01:22PM |
Re: Mouting FoldaRap 2.5 - heeeeelp plz December 29, 2016 02:16PM |
Re: Mouting FoldaRap 2.5 - heeeeelp plz December 29, 2016 03:00PM |
FA-MAS
You'll be ok removing the leaver from the switch.
FA-MAS
I'd say don't hook up either the heated bed heater or the hotend heater.
Do your thermistors first. They're simple resistors that change resistance with heat
FA-MAS
Both the bed and hotend temperature should read temperatures close to each other, as well as the ambient temperature in the room
If they're reading something, but they're off, it's probably the wrong thermistor defined in firmware
Re: Mouting FoldaRap 2.5 - heeeeelp plz March 05, 2017 05:56PM |
Re: Mouting FoldaRap 2.5 - heeeeelp plz March 10, 2017 05:44AM |
