One pin of the PP connector is connected to the thermistor ground and the other goes to the spare wire on the ribbon cable.
12V is already available at the heater terminal. I think it is a second ground that people use the probe connection for to drive a second fan. You don't want to share the thermistor ground with anything that draws significant current or generates noise.
www.hydraraptor.blogspot.com]
