Extruder heater turning off mid print.
Posted by Anonymous User
Anonymous User
October 24, 2013 05:16PM
I have a repeated problem wherein the extruder heater itself off turns off and the print fails. Any ideas?
Re: Extruder heater turning off mid print.
October 25, 2013 05:02AM
Bad connection to the heater or thermistor. Does it give an error message like MAXTEMP or MINTEMP exceeded?
Anonymous User
October 25, 2013 07:23AM
No, it happens at the same point if I repeat a print aswell.
October 25, 2013 08:01AM
Must be something in the gcode then.
October 25, 2013 03:42PM
It could be caused by pressing the heater off button on Pronterface while uploading to the SD card. Any manual commands you do while that is happening get mixed in with the gcode on the SD card.
Edited 1 time(s). Last edit at 10/26/2013 10:05AM by nophead.
Anonymous User
October 25, 2013 08:33PM
eek! Thanks. That sounds likely. I'll reload the gcode and try again.
Anonymous User
October 26, 2013 09:35AM
Thanks again - that solved it :-)
