Hit XYZ Stops and Center Each Time Printer is Connected? November 04, 2013 03:24PM |
Re: Hit XYZ Stops and Center Each Time Printer is Connected? November 04, 2013 03:54PM |
Re: Hit XYZ Stops and Center Each Time Printer is Connected? November 04, 2013 04:04PM |
QuackingPlums
That step in the manual is just to prove that once you "home" the axes, that you can't then hit the end-stops in normal use due to the firmware limits. In normal printing your gcode will include a G28 command to home all axes before beginning the print so from there on in you should be fine.
Re: Hit XYZ Stops and Center Each Time Printer is Connected? November 04, 2013 05:02PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Hit XYZ Stops and Center Each Time Printer is Connected? November 04, 2013 05:54PM |
