The bolt I have for my extruder is an EBay purchase, I think from Geetech. The hobbing is nice and neat, but there is no groove in the bolt: the hobbing is directly on the surface diameter of the bolt. Is that groove necessary, especially if I am using 3mm filament? Or do I need to try to re-hob the bolt myself after cutting a groove?
If I DO re-hob the bolt, what size tap should I use? I live in the USA, so SAE taps are more common, but I can get metrics from work, if necessary, though the selection is somewhat limited.
