Mendel with Melzi electronics but only X in one direction and hot end works
Posted by yagoa
November 22, 2014 06:33PM
Dear Reprappers smiling smiley
What I was wondering is if someone could share their firmware that is working, or has a clue what is wrong?
I got no errors while uploading bootrom or firmware but when I connect in Pronterface I get a lot of echo stuff.
Fyi this setup has worked before.
Connecting...
start
Printer is now online.
echo: External Reset
Marlin 1.0.2 RRP
echo: Last Updated: 2014-06-02-AB | Author: RRP
echo: Free Memory: 11513 PlannerBufferBytes: 1232
echo: Using Default settings:
echo: Steps per unit:
echo: M92 X87.489 Y87.489 Z4000.000 E660.000
echo:Maximum feedrates (mm/s):
echo: M203 X300.000 Y300.000 Z3.000 E45.000
echo:Maximum Acceleration (mm/s2):
echo: M201 X800 Y800 Z30 E250
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S1000.000 T1000.000
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s), K=advance_k
echo: M205 S0.000 T0.000 B20000 X15.000 Z0.400 E15.000
echo: M206 X0.000 Y0.000 Z0.000
echo: M208 X210.000 Y210.000 Z140.000
echo: PID settings:
echo: M301 P12.000 I2.200 D80.000 W125
echo:Thermistor settings: M304 Hh Bb Rr Tt, H0=Bed, H1..n=nozzle, b=thermistor beta value, r=series resistor, t=thermistor resistance as 25C
echo: M304 H0
B3988 R10000 T10000 M304 H1
B4138 R10000 T100000
FPU Enabled no
transform correction not enabled
echo: SD init fail
Thanks in advance!
Happy printing!
Edited 1 time(s). Last edit at 11/22/2014 06:45PM by yagoa.
Re: Mendel with Melzi electronics but only X in one direction and hot end works
November 22, 2014 06:36PM
I have 2 Melzi boards and get the same issue with both...
Edited 3 time(s). Last edit at 11/22/2014 06:48PM by yagoa.
November 22, 2014 09:52PM
Is this anything to do with Mendel90? Looks like your firmware is for an RRP Mendel, in which case this is the wrong forum.
