The plastic (PLA) have been deformed and can´t get in the hotend. I have read that I can take a heat gun and warm up the cold end of the hotend but I don´t have one. I also read that I can put the hotend on the bed and insulate it and heat it to 80, but the problem with that is that the printer won´t turn on because the hotend is disconnected. Is it possible to put the hotend, with the red insulating tape and the green and the red wires, in the oven and heat it to 80C and then try to pull the plastic out?
Do I need to remove all plastic or is it enough to just remove the blocking part and then install it in the printer again and just insert the filament to push it in the hotend?
Any help is very much appreciated!
