Wade Reloaded Extruder for E3D-V6? March 25, 2015 07:34PM |
Re: Wade Reloaded Extruder for E3D-V6? March 26, 2015 06:10AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Wade Reloaded Extruder for E3D-V6? March 26, 2015 09:42AM |
I've been using the Reloaded extruder for the past 8 months or so. Other than printing it as a mirror image so that the motor is on the left instead of right, I haven't had any problems with it interfering with anything.Quote
nophead
I don't think Greg's will fit because the motor sticks out further.
Re: Wade Reloaded Extruder for E3D-V6? March 26, 2015 12:29PM |
Re: Wade Reloaded Extruder for E3D-V6? March 26, 2015 05:49PM |
nophead
If your extruder is working properly you shouldn't need to clean the hobbed bolt. The teeth only get clogged if it slips. If it never slips all you get is a bit of dust that doesn't affect its grip.
If you do need to clean it just undo the nuts M8 nuts and slide it out along with the big gear. You then get far better access for cleaning and you don't need to disturb the spring tension. This is why I use plain gears rather than herring bone. You can't slide the bolt out easily with herring bone, hence why Greg's was born.
I don't think Greg's will fit because the motor sticks out further. I think it will hit the X idler. I removed the need to access the bolt under the motor by using a captive hex screw instead of a nut.
Re: Wade Reloaded Extruder for E3D-V6? March 26, 2015 08:33PM |
Re: Wade Reloaded Extruder for E3D-V6? March 26, 2015 09:11PM |
I am thinking about backlash on retraction, though, and the E3D uses MUCH less retraction than a J-head (about 0.6mm or so).Quote
nophead
I don't think backlash matters on the extruder as it only extrudes in one direction.
How would I go about doing that?Quote
nophead
I can't see any point to the rotated motor so it could be put back flat to make it shorter.
Re: Wade Reloaded Extruder for E3D-V6? March 27, 2015 05:24AM |
Re: Wade Reloaded Extruder for E3D-V6? March 27, 2015 08:45AM |
Re: Wade Reloaded Extruder for E3D-V6? March 30, 2015 09:33AM |
I remembered to double checked over the weekend and you are correct. It does touch the x idler bracket. I never print something a full 200mm across so I just knocked off 10mm on that side of the bed. It was an acceptable compromise for me at the time to gain some of the features the reloaded extruder offered.Quote
nophead
I don't understand how that can be as there is only a couple of mm clearance with the motor mounted square. Slanting it must make the extruder longer.
