Mendel90 Auto Bed Leveling March 22, 2015 09:58AM |
Re: Mendel90 Auto Bed Leveling March 22, 2015 01:13PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Mendel90 Auto Bed Leveling March 22, 2015 01:53PM |
Re: Mendel90 Auto Bed Leveling March 22, 2015 06:06PM |
Re: Mendel90 Auto Bed Leveling March 22, 2015 06:56PM |
Re: Mendel90 Auto Bed Leveling March 23, 2015 03:45AM |
Re: Mendel90 Auto Bed Leveling March 23, 2015 09:28AM |
Re: Mendel90 Auto Bed Leveling March 23, 2015 09:33AM |
Re: Mendel90 Auto Bed Leveling March 23, 2015 10:22AM |
Re: Mendel90 Auto Bed Leveling March 23, 2015 11:18AM |
Re: Mendel90 Auto Bed Leveling March 23, 2015 03:51PM |
I have a capacitive one that takes 3 or 7mA depending if the LED is on. I measured the resistance between the probe ground and the Melzi as 0.26R. That would give a voltage drop of nearly 2 mV, which is below the resolution of the 10 bit ADC.
Re: Mendel90 Auto Bed Leveling March 23, 2015 07:26PM |
Re: Mendel90 Auto Bed Leveling March 24, 2015 01:39PM |
Re: Mendel90 Auto Bed Leveling March 24, 2015 06:15PM |
Re: Mendel90 Auto Bed Leveling March 25, 2015 10:54AM |
Re: Mendel90 Auto Bed Leveling March 25, 2015 12:26PM |
Re: Mendel90 Auto Bed Leveling March 25, 2015 02:16PM |
Re: Mendel90 Auto Bed Leveling March 25, 2015 02:56PM |
Re: Mendel90 Auto Bed Leveling March 25, 2015 03:57PM |
Re: Mendel90 Auto Bed Leveling March 25, 2015 04:25PM |
Re: Mendel90 Auto Bed Leveling March 25, 2015 06:23PM |
D4RK1
ok.. so there is no hope ^^, at least on the capacitive front and using a glass sheet. By the way... the bed leveling process, from what I understand, the software will use the measurement to "tilt" the object relative to the measured surface.
D4RK1
About the measuring, will it in essence just measure 3 to 4 points on the bed and then use those measurements or will it measure more points?
D4RK1
And if more points, what will it do, will it simply take an average of those measurements (plot a plane through them that fits best) or will it also map bumps and holes? So if there is a "hollow" will the extruder "dip" into it while traveling over it? (Doesn´t seem too useful, since it would do that for every layer of the print, so I guess this is not it )
D4RK1
If it uses say 4 corner points to map the bed, it could be possible to use points on the edge of the bed and maybe apply thin metal foil to the glass on these points?
Re: Mendel90 Auto Bed Leveling March 26, 2015 04:42PM |
Re: Mendel90 Auto Bed Leveling March 26, 2015 08:26PM |
Re: Mendel90 Auto Bed Leveling March 27, 2015 01:51PM |
Re: Mendel90 Auto Bed Leveling March 27, 2015 02:21PM |
Re: Mendel90 Auto Bed Leveling March 29, 2015 07:53AM |
Re: Mendel90 Auto Bed Leveling March 29, 2015 09:53AM |
Re: Mendel90 Auto Bed Leveling April 01, 2015 09:28AM |
Re: Mendel90 Auto Bed Leveling April 01, 2015 11:48AM |
Re: Mendel90 Auto Bed Leveling April 01, 2015 12:02PM |
