Searching a STL for RAMPS module on I3 acrylic October 18, 2015 03:49AM |
Re: Searching a STL for RAMPS module on I3 acrylic October 27, 2015 10:20AM |
Re: Searching a STL for RAMPS module on I3 acrylic October 27, 2015 11:49AM |
//change the next 6 lines to match your dimensions dim=20; //the width/height of the extrusion wall=4; //how thick you want the walls to be height = 50; //the length of the "sleeve" hookwall = 6; //how thick is the wall aroung the "hook" portion hookdepth = 6; //how wide is the aluminum over which the hook is hung hookheight = 12; //how long is the portion of the hook that overhangs the aluminum //don't change below this point dim2 = (dim/2+wall)*sin(45); rotate([0, 90, 0]) difference() { union() { rotate([-45, 0, 0]) translate([0, 0, height/2]) cube([dim+wall*2, dim+wall*2, height], true); cube([dim+wall*2, dim2*2, dim2*4], true); translate([0, -dim2-(hookdepth+hookwall)/2, dim2]) cube([dim+wall*2, hookdepth+hookwall, hookwall], true); translate([0, -dim2-hookwall/2-hookdepth, dim2+hookwall/2-hookdepth/2-hookheight/2]) cube([dim+wall*2, hookwall, hookdepth+hookheight], true); } rotate([-45, 0, 0]) translate([0, 0, height/2+wall]) cube([dim, dim, height], true); }
Re: Searching a STL for RAMPS module on I3 acrylic November 15, 2015 12:10AM |
