Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 17, 2016 02:59PM |
#define FILAMENT_RUNOUT_SENSOR // Uncomment for defining a filament runout sensor such as a mechanical or opto endstop to check the existence of filament // In RAMPS uses servo pin 2. Can be changed in pins file. For other boards pin definition should be made. // It is assumed that when logic high = filament available // when logic low = filament ran out #if ENABLED(FILAMENT_RUNOUT_SENSOR) const bool FIL_RUNOUT_INVERTING = false; // Should be uncommented and true or false should assigned #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined. #define FILAMENT_RUNOUT_SCRIPT "M600 X3 Y3 E-100" #endif
// Temperature status LEDs that display the hotend and bet temperature. // If all hotends and bed temperature and temperature setpoint are < 54C then the BLUE led is on. // Otherwise the RED led is on. There is 1C hysteresis. //#define TEMP_STAT_LEDS
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 18, 2016 09:02AM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 18, 2016 09:05AM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 18, 2016 09:16AM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 18, 2016 11:20AM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 18, 2016 02:03PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 18, 2016 04:18PM |
// Uncomment below to enable //#define FILAMENT_WIDTH_SENSOR #define DEFAULT_NOMINAL_FILAMENT_DIA 3.00 //
#define FILAMENT_RUNOUT_SENSOR // Uncomment for defining a filament runout sensor such as a mechanical or opto endstop to check the existence of filament // In RAMPS uses servo pin 2. Can be changed in pins file. For other boards pin definition should be made. // It is assumed that when logic high = filament available // when logic low = filament ran out #if ENABLED(FILAMENT_RUNOUT_SENSOR) const bool FIL_RUNOUT_INVERTING = false; // Should be uncommented and true or false should assigned #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined. #define FILAMENT_RUNOUT_SCRIPT "M600" #endif //////////////////////////////////////////////////////////////////////////////////////////////////// //#define EXTRUDER_RUNOUT_PREVENT #define EXTRUDER_RUNOUT_MINTEMP 190 #define EXTRUDER_RUNOUT_SECONDS 30. #define EXTRUDER_RUNOUT_ESTEPS 14. //mm filament #define EXTRUDER_RUNOUT_SPEED 1500. //extrusion speed #define EXTRUDER_RUNOUT_EXTRUDE 100 //////////////////////////////////////////////////////////////////////////////////////////////////// #if ENABLED(ULTIPANEL) #define FILAMENTCHANGEENABLE #if ENABLED(FILAMENTCHANGEENABLE) #define FILAMENTCHANGE_XPOS 3 #define FILAMENTCHANGE_YPOS 3 #define FILAMENTCHANGE_ZADD 10 #define FILAMENTCHANGE_FIRSTRETRACT -2 #define FILAMENTCHANGE_FINALRETRACT -100 #define AUTO_FILAMENT_CHANGE //This extrude filament until you press the button on LCD #define AUTO_FILAMENT_CHANGE_LENGTH 0.04 //Extrusion length on automatic extrusion loop #define AUTO_FILAMENT_CHANGE_FEEDRATE 300
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 19, 2016 02:01PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 19, 2016 02:04PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 20, 2016 04:13AM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 20, 2016 08:42AM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 20, 2016 02:54PM |
Admin Registered: 9 years ago Posts: 215 |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 20, 2016 03:04PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 20, 2016 03:19PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 22, 2016 03:31PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 22, 2016 07:10PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 29, 2016 11:38AM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 29, 2016 02:21PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 30, 2016 08:16PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 30, 2016 08:46PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 31, 2016 04:37AM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? May 31, 2016 10:57AM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? June 01, 2016 04:36PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? June 01, 2016 07:20PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? June 01, 2016 07:53PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? June 02, 2016 07:33PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? June 03, 2016 08:43AM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? June 03, 2016 10:04AM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? June 03, 2016 02:29PM |
Re: Filament Runout Sensör ? ve Sıcaklık Durum Ledi ? June 03, 2016 03:15PM |
