How do you round the top and bottom of a tube? February 15, 2015 11:25AM |
Re: How do you round the top and bottom of a tube? February 15, 2015 05:08PM |
Re: How do you round the top and bottom of a tube? February 16, 2015 04:56AM |
$fn=100; // reduce this for printing Rounded_tube(100, 20, 5); module Rounded_tube(height, radius, wall_thickness) { ff = 0.05; // CSG fudge factor // upper toroidal lip translate([0, 0, height/2-wall_thickness]) rotate_extrude() translate([radius-wall_thickness/2, 0, 0]) circle(d=wall_thickness); // lower toroidal lip translate([0, 0, wall_thickness-height/2]) rotate_extrude() translate([radius-wall_thickness/2, 0, 0]) circle(d=wall_thickness); // bridge it with a tube difference() { cylinder(h=height-2*wall_thickness, r=radius, center=true); cylinder(h=height, r=radius-wall_thickness, center=true); } }
Re: How do you round the top and bottom of a tube? February 16, 2015 05:14AM |
$fn = 100; Rounded_hole(100, 30, 5); module Rounded_hole(depth, radius, bevel_radius) { difference() { cylinder(h=depth, r=radius+bevel_radius, center=true); //elongated torus rotate_extrude() hull() { translate([radius+bevel_radius, depth/2-bevel_radius, 0]) circle(r=bevel_radius); translate([radius+bevel_radius, bevel_radius-depth/2, 0]) circle(r=bevel_radius); } } }
Re: How do you round the top and bottom of a tube? February 16, 2015 07:36AM |
Re: How do you round the top and bottom of a tube? February 17, 2015 01:08PM |
Re: How do you round the top and bottom of a tube? February 18, 2015 05:13AM |
$fn = 100; t = 5; td = 20; bd = 15; h = 30; difference() { cylinder(r1=bd, r2=td, h=h, center=true); cylinder(r1=bd-t, r2=td-t, h=h+0.01, center=true); } translate([0,0,h/2]) color("green") torus(td, t/2, h); translate([0,0,-h/2]) color("blue") torus(bd, t/2, h); module torus(d, r, h) { rotate_extrude() { translate([d-r,0,0]) circle(r = r); } }
Re: How do you round the top and bottom of a tube? February 18, 2015 05:28AM |
appjaws1
whilst maintaining the overall height of say 30?
h = 30;use:
h = 30 - t;
Re: How do you round the top and bottom of a tube? February 18, 2015 05:36AM |
Re: How do you round the top and bottom of a tube? February 18, 2015 07:20AM |
Re: How do you round the top and bottom of a tube? February 18, 2015 08:34AM |
QuackingPlums
Isn't that what I did Bob? ;-)
appjaws1
I assume that a teardrop is constructed from a cube and a cylinder
Re: How do you round the top and bottom of a tube? February 18, 2015 08:50AM |
$fn = 100; t = 5; td = 20; bd = 15; h = 30 - t/2 - sqrt(2)*t/2; difference() { cylinder(r1=bd, r2=td, h=h, center=true); cylinder(r1=bd-t, r2=td-t, h=h+0.01, center=true); } translate([0,0,h/2]) color("green") torus(td, t/2, h); translate([0,0,-h/2]) color("blue") tearus(bd, t/2, h); module torus(d, r, h) { rotate_extrude() { translate([d-r,0,0]) circle(r = r); } } module tearus(d, r, h) { rotate_extrude(convexity=10) { translate([d-r,0,0]) union() { circle(r); rotate(-135) square(size=r,center=false); } } }
Re: How do you round the top and bottom of a tube? February 18, 2015 09:40AM |
Re: How do you round the top and bottom of a tube? February 18, 2015 12:53PM |
Re: How do you round the top and bottom of a tube? May 10, 2015 05:00AM |
Admin Registered: 11 years ago Posts: 1,063 |
$fn=127; diameter = 10;// outerdiameter india=5; // innerdiameter length=20; // overall length rad=diameter-india; offset=diameter/2-rad/4; union(){ translate([0,0,rad/4])rotate_extrude()translate([offset,0,0])circle(r=rad/4); #translate([0,0,length-rad/4])rotate_extrude()translate([offset,0,0])circle(r=rad/4); difference(){ translate([0,0,rad/4])cylinder(r=diameter/2,h=length-rad/4-rad/4); translate([0,0,1])cylinder(r=india/2,h=length);// if you don't want the hole in the middle then remove this line } }
Re: How do you round the top and bottom of a tube? May 10, 2015 08:15AM |
Re: How do you round the top and bottom of a tube? May 23, 2015 03:28AM |
Re: How do you round the top and bottom of a tube? May 23, 2015 07:57AM |
o_lampe
I love it, how we have to read from right to left, to understand, what´s going on
Or in other cases, "from bottom up"
-Olaf
