Predictability of scale....
December 24, 2016 01:18AM
I am fond of Scale.
But there is a question on the usage:
When I want to make a hollow object, with predefined wall thickness,
I design the object and Difference it with a scaled smaller copy, that is translated in Z, to a defined altitude that reflects the wall thickness on the build plate.
However, the thickness of other walls: left, right, front, rear and top , (or with more complex objects all other outside surfaces) is depending on the scale parameters.
Can I calculate the thickness as a function of both the original size and the desired thickness, to get the scale parameter ?
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: Predictability of scale....
December 24, 2016 09:58AM
Your proposed approach using a difference with a scaling version of the full object to get a predefined wall thickness will not work in general. It will only work for very specific simple shapes (such as cubes and spheres), since it will result in a variable wall thickness that is essentially proportional to the distance from the origin.
What you would need to do this computing the Minkowski difference of you object and a sphere with a radius equal to the wanted wall thickness and subtract the result from the original object. But, unfortunately, OpenScad only implements the Minkowski sum, not the difference... sad smiley
The only "easy solution" I could see, is to let the slicer do the work by printing the full object with a 0% filling and the number of shells and top/bottom layers that correspond to the desired wall thickness.
December 25, 2016 07:01AM
I was not aware of a possible minkowsky difference . Enyhow it is not there confused smiley
Your solution gives me a hard time programming internal ribs and supports in the hollow shape, as far as I can think-up now.
But I will keep it in mind designing. Thanks
January 26, 2017 09:54AM
Just a note regarding the Minkowski difference: In this other thread I proposed a simple implementation of the Minkowski difference using the Minkowski sum on the "negative" (i.e. a cavity) of the original object...
