how can i create a polygon that would encompass all this shapes?
Posted by emaayan
February 11, 2018 03:01PM
consider the following file..
is there anyway i can somehow create a polygon based on the manArr variable, that would encompass all the cylinders, without cutting through them?
so far the only way i think of is doing somehow a recursive function, but opensCad's restrictions on functions to be one line is driving me insane..
open | download - BatteryCellHolderGenerator.scad (3.8 KB)
Re: how can i create a polygon that would encompass all this shapes?
February 11, 2018 03:32PM
Is the hull() function any use to you?
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
February 11, 2018 04:31PM
it certainly does , now if i could just offset, but i'm guessing i'm gonna have to re-do the function that creates the cells, to use circles and not cylinders so the hull would be 2d..
February 11, 2018 10:27PM
OpenScad has an offset function: [en.wikibooks.org]
The Help menu links to a "Cheat Sheet", which is a great help for finding out what is available.
February 12, 2018 01:54AM
emaayan
You could also use projection() to project the hull into a 2D-polygon.
February 12, 2018 02:00AM
i have the cheet sheet bookmarked in my browser, smiling smiley doesn't mean i always understand it ...
isn't the projection involves creating external files first?
February 12, 2018 08:09AM
emaayan
No, it will project whatever object follows, so e.g. "projection()cylinder(r=10,h=5);" will create a circle.
February 13, 2018 03:01AM
so this is my new use of hull and projection
open | download - BatteryCellHolderGenerator.scad (8.4 KB)
February 13, 2018 10:47AM
hi.. the hull method did helped, but it also helped to know what i want, in terms of terminology,
what i'm REALLY looking for is CONCAVE hull, i want the hull to be minimal , and not a Convex one, i've been trying to see if anyone wrote a library for it... but i'm not sure..
enif
emaayan
February 13, 2018 01:36PM
As far as I understand there is no such thing as a "concave hull", as this would degenerate essentially to the union with a tiny connection tree between the loose parts. But maybe what you could use is the union of the convex hulls of smaller subsets, e.g. of the straight rows of cylinders, in order to get a closer "shell" around the cells.
February 13, 2018 02:14PM
you mean hull each shape on it's own instead of the whole thing?
how about doing it as a module, the hull would be created bu doing a hexagon, and subtract it from the real shapes:
translate([0,0,holderActuallHeight]){
drawHoles(manArr){
translate([0,0,0]){
if (hullIt){
rotate([0,0,30]){
circle(d=(cellDiameter*3/2),$fn=6);
}else{
translate([0,0,-stripZ]){
cylinder(d=cellDiameter,h=holderHeight+0.3);
actuallstripWidth= stripWidth;
actuallStripLength=stripLength+0.001;
square([actuallStripLength,actuallstripWidth],center=true);
rotate(angle){
rotate(angle*2){
seems it was requested already [github.com]
February 14, 2018 05:51AM
Yes, the idea of combining the shell from outer hexagons seems nice...
As for your code itself, I admit that I have not tried understand it completely. I do like the idea with the drawHoles() iterator. However,
do you know that if you use variables starting with $ (e.g. $col, $row)they can be accessed by the children(). This would allow you to make a much leaner iterator and access e.g. the cell position and contents of the corresponding manArr entry inside the child code.
With drawHoles() being a simple iterator you could easily split the problem into components like outer shell, inner cavity, cell cylinders, etc.
The following is just to illustrate the idea:
// cell configuration
n=-1; p=1;
simpleOne=[
         [p,n,p]
        ,[p,n,p]
        ,[p,n,n]
        ,[p,n]
        ,[p,n]
        ,[p]
module batterycase(cells,dia=18,len=65,wall=10,wallz=4){
   // cell position of cells[r][c]
   function cellpos(r,c)=[(2*$row+($col%2)),2*cos30*$col,0];
   // Local module to iterate through all cells
   // Variables $row, $col are global, so they can be used in all children
   module drawHoles(){
      for($row=[0:len(cells)-1])
         for($col=[0:len(cells[$row])-1])
            translate(radius*cellpos($row,$col)) children();
   // Local module to draw a + or -
   module pole(s)
   {for(a=[0: (s>0?90:180):359])rotate(a)translate([0,-1,0])cube([4,2,1]);}
   cos30 = cos(30);
   radius=dia/2+0.5;
   difference(){
      // outer shell
      union()drawHoles()
         cylinder(r=dia/2+wall,h=len+2*wallz,$fn=6);
      // inner cavity
      union() translate([0,0,2*wallz])drawHoles()
         rotate(30)cylinder(r=dia/2/cos30+1,h=len-2*wallz,$fn=6);
      // individual cell cylinders
      drawHoles(){
         // cell cavity
         translate([0,0,-0.1]) cylinder(r=dia/2,h=len+2*wall+0.2);
         // show polarity on top and bottom
         %translate([0,0,2*wallz+len-1])pole(cells[$row][$col]);
         %translate([0,0,-1])pole(-cells[$row][$col]);
         // ... and whatever else is needed
batterycase(simpleOne);
BTW, the idea with the alpha-shape as a kind of parametric "concave hull" is indeed interesting - thanks for mentioning it!
February 14, 2018 08:37AM
actually someone just mentioned this to me, i was looking or something like this, after i saw [github.com] library which initially looked like doing a lof of this things i'm doing .. i knew it would make things simpler this way..
btw my recent changes seems to make scad behave ...weird, something i the rendering doesn't seem right. pressing F6 ,usually shows it ok after, but still...
my original plan was to upload all of this to thingiverse, but i don't think it has a ui. for setting the arrays.
all of this is a compromise, it would be sooo much cooler if instead if could just define a polygon and have it be filled optimally like in here: [e4bike.ru]
but i lack the algorithm chops do it ...so i took the structured way..
