nove drivre a stisenie tlaciarne December 09, 2014 03:40PM |
Re: nove drivre a stisenie tlaciarne December 09, 2014 05:24PM |
Re: nove drivre a stisenie tlaciarne December 10, 2014 02:50AM |
Re: nove drivre a stisenie tlaciarne December 10, 2014 04:02AM |
Moderator Registered: 10 years ago Posts: 1,038 |
Re: nove drivre a stisenie tlaciarne December 10, 2014 07:30AM |
raptik
Ten hluk bude loziskama a muzes zkusit zmenit jine zapojeni civek motoru nebo pripadne poladit proud motoru. Ten driver je schopen dat vic nez predeslej. A nekdy staci promazat...
Ja je mam a tichost oproti a4998 je hodne znat i na 1/32.
Ten tisk, bud smajdaj zavitovky, nespravne sedi zvedaci matky v x endech, volny loziska lm8uu na osach, vada davkovani plastu...
Jo a promazani zavitovky mi taky parkrat pomohlo od podobneho zvlneni...
Re: nove drivre a stisenie tlaciarne December 10, 2014 09:46AM |
Moderator Registered: 12 years ago Posts: 803 |
Re: nove drivre a stisenie tlaciarne December 11, 2014 09:28AM |
Bajn
u igus pozor na dve veci,
1) maji vnejsi prumer 19mm misto 18mm ktere maji lm8uu.
2) potrebuji kovovy domecek, pokud je pouze dotahnes stahovaky, tak se porusi jejich kulatost a drhnou.
Muzes zkusit pripadne loziska vytisknout, ja uz 2 mesice jedu na PLA loziskach a nezaznamenal jsem zadny problem (pouze x a y osa, pro zetko to kvuli utiseni nema cenu)
Re: nove drivre a stisenie tlaciarne December 11, 2014 11:37AM |
Re: nove drivre a stisenie tlaciarne December 11, 2014 03:16PM |
raptik
viz: [www.google.cz]
je to jen pro nazornost, ty barvy budes mit asi jine, nevim jake mas motorky
jestli se nepletu, budes mit seriove zapojeni (dva draty propojene a dva a dva do driveru), ale jde menit jen u 8 dratoveho motoru
Re: nove drivre a stisenie tlaciarne December 11, 2014 04:15PM |
Re: nove drivre a stisenie tlaciarne December 13, 2014 05:45AM |
tak som si vytlacil 4ks puzdier z pla ale asi mam zle nastavene tyce lebo doska ide trosku tazko.Quote
raptik
jestli mas 4 draty, nic s tim nenadelas...
Re: nove drivre a stisenie tlaciarne December 13, 2014 07:06AM |
