netopi deska help ramps1.4 merlin January 18, 2015 03:11PM |
pres kontrolni lcd zadam teplotu a nic kdyz ji odpojim a pripojim primo na zdroj tak deska bez problemu nahriva nevite nekdo v cem muze byt zakopany pes??nic jineho nez tohle co jsem popsal zapojene nemam
Re: netopi deska help ramps1.4 merlin January 19, 2015 04:03PM |
Moderator Registered: 13 years ago Posts: 1,038 |
Re: netopi deska help ramps1.4 merlin January 19, 2015 04:16PM |
Re: netopi deska help ramps1.4 merlin January 19, 2015 04:34PM |
Re: netopi deska help ramps1.4 merlin January 19, 2015 07:04PM |
Re: netopi deska help ramps1.4 merlin January 19, 2015 07:06PM |
Re: netopi deska help ramps1.4 merlin January 22, 2015 04:25PM |
Re: netopi deska help ramps1.4 merlin January 23, 2015 03:53AM |
Re: netopi deska help ramps1.4 merlin January 23, 2015 05:43AM |
Re: netopi deska help ramps1.4 merlin January 24, 2015 07:50PM |
Moderator Registered: 14 years ago Posts: 803 |
Re: netopi deska help ramps1.4 merlin January 25, 2015 04:56AM |
Re: netopi deska help ramps1.4 merlin January 25, 2015 06:23AM |
Re: netopi deska help ramps1.4 merlin January 25, 2015 06:39AM |
Re: netopi deska help ramps1.4 merlin January 25, 2015 07:05AM |
deska je mk2 cervena kdyz ji dam naprimo na zdroj tak se rozsviti 2 ledky ktere jsem tam spolu s odporem napajel a okamzite hreje za necelych 5 minut jsem tam mel 70stupnu kdyz jsem ji zkousel jak dorazila|
Re: netopi deska help ramps1.4 merlin January 25, 2015 07:12AM |
Re: netopi deska help ramps1.4 merlin January 25, 2015 08:18AM |
Re: netopi deska help ramps1.4 merlin January 25, 2015 08:56AM |
Re: netopi deska help ramps1.4 merlin January 25, 2015 10:30AM |
Re: netopi deska help ramps1.4 merlin January 25, 2015 10:51AM |
Ditr
tady to je promin už jsem z toho zase rozhozený že to pořád nejede ted sem zase něčím rozhodil osu X nehomujemoje nervy
dam home y,z sjede do pozice home ke koncaku a jedinne x se posune 1cm od koncaku
Re: netopi deska help ramps1.4 merlin January 25, 2015 11:17AM |
Re: netopi deska help ramps1.4 merlin January 25, 2015 11:47AM |
Re: netopi deska help ramps1.4 merlin January 25, 2015 12:42PM |
raptik
Ditr
no podel toho co sem koukal na zdrojaky marlinu, tak aktualni nemas, jestli si neposlal spatnej configure...
mas tam minimalne rozdil v definici pro elektroniku... nove pouzivaj definici z boards.h a ne cislo...
ad konfig:
pouzivas dva termistory na hotend???
#define TEMP_SENSOR_0 5
#define TEMP_SENSOR_1 1
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 1
jestli ne nastav TEMP_SENZOR_1 0
pokud mas jen endstopy na homing (3 ks) odkomentuj:
//#define DISABLE_MAX_ENDSTOPS
podle tohohle soudim, zes spis poslal nakej default:
#define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402,78.7402,200.0*8/3,760*1.1}
nebo mas tenhle setup???
Re: netopi deska help ramps1.4 merlin January 25, 2015 03:10PM |
Extruder ti nefunguje preto, lebo je tam aktivovaná SW poistka aby neextrudovalo, pokiaľ teplota nedosiahne určitú teplotu.Quote
Ditr
jeste jeden dotaz ted jsem zapojil extruder patri pod nej jumpry na microstepy?? mam tam vsechny 3 ale extruder mi nejak nechce fungovat jak kdyby byl slaby motor
Re: netopi deska help ramps1.4 merlin January 25, 2015 03:19PM |
Re: netopi deska help ramps1.4 merlin January 25, 2015 05:30PM |
musi se to relativne volne tocitQuote
Ditr
teplotu mam nahratou desku taky motor extruderu vrci a skube i kdyz na driveru pridam nebo uberu tak se proste nechce tocit kdyz sundam ozubene kola tak jede bez jakehokoli problemu zda se mi jako by ten motor byl slaby a neutahnul to
Re: netopi deska help ramps1.4 merlin January 25, 2015 05:32PM |
Bulman
Ditr
Mal by to byť riadok:
#define EXTRUDE_MINTEMP 180
kde 180 je minimálna teplota odkedy začne extruder točiť. Zamedzuje to vydratiu vlákna zubaticou.
Ak chceš iba testovať nasucho, tak si tam nastav menšiu teplotu, alebo tú funkciu dočasne deaktivuj.
Re: netopi deska help ramps1.4 merlin January 30, 2015 02:23PM |
Re: netopi deska help ramps1.4 merlin January 30, 2015 03:27PM |
Re: netopi deska help ramps1.4 merlin January 30, 2015 04:21PM |
