sid
Corrupted posts -- please fix!
February 07, 2009 01:17PM
Hi there,
somehow all nonenglish characters are not allowed anymore;
even worse the rest of the posting isn't shown anymore.
Hopefully it's just a decoding problem and the database is still in complete.
Yesterdays hint on this subject:
[forums.reprap.org]
And today the german subforum is almost useless too.
If you need any help with that, just drop me a line,
made the same mistake once, I think I can fix it (faultless database presumed)
'sid
sai
Re: Corrupted posts -- please fix!
February 07, 2009 11:34PM
Please see
[forums.reprap.org]
Unfortunately the issue with MySQL compatibility causes the INSERT statement content to also be truncated. Since a part of the upgrade process is to dump all tables and re-insert into a new database, this obviously creates a major problem. Unfortunately, MySQL did not display any warnings that it was wilding truncating data.
sid
February 08, 2009 04:19AM
Hi Simon,
is any old version of the sql available (that is, do you have any recent backup) ?
The problem there is mostly not what SQL does, but what php has done before.
I guess you've updated via php-scripts, didn't you.
As I noted in the report, adding a htmlencode to the message before it is written somewhere helps not to loose anything almost everytime; beyond that further steps are to be taken like escaping special characters and decoding some characters after reading from the database.
I can't recall which php version was the odd one, but it wasn't that long ago since they changed some functions (which made this error appear).
If you do have a backup of the old db please drop me a PM;
I may find a way out.
that is if you want me to help of course winking smiley
'sid
VDX
February 26, 2009 03:07AM
... is there any solution for repair of the truncated posts?
I found my stored PM's truncated too and most of the posts in the german forum are senseless now ...
Viktor
