Deleting usefull information from the Wiki February 06, 2017 11:37AM |
The page has been flagged as advertising for an invalid reason:
This page is found to exist for the sole purpose of Advertising, This page will eventually be removed.
Reason: no sources, does not comply with lowest common denominator of opensource
microfortnight
Dark Alchemist
That is why I said to mention it BUT label it as closed source and any information needs to be had from the seller or the manufacturer.Quote
microfortnight
Dust
Personally I think removing it just because it doesn't comply with open source is very silly
I also wouldn't remove these entries. It's a good opportunity to brand these boards as not open-source.
It already saved me from buying one of those boards.
I think nobody removed these pages until now because it doesn't make much sense, only few people care and it is some editing work involved.
Here's a different view on this topic:
RepRap is also about Open-Source Software, there are a lot of firmware implementations around.
This board is well supported by open-source firmware implementations.
So I still think it's not a good idea to remove any valuable information from the Wiki.
In this specific case there are two pages for this board.
MKS_BASE_1.0, no flags at all
MKS_BASE not open source, advertising
There were some edits after one page has been flagged as advertising.
Both pages contains some configuration hints for Marlin, some advice on VCP drivers, a lot of useful information I guess.
So I don't think there actually is advertising on these pages.
In my opinion, it would be better to merge these pages and improve the Wiki:
1) Remove the reasons for the advertising flag (cannot see any)
2) Remove the advertising flag
3) Keep the not open-source flag
4) Repeat for other boards/shields, at least for the popular ones like RADDS, etc.
Maybe you should collect some more opinions before deleting these pages.
Re: Deleting usefull information from the Wiki February 06, 2017 12:30PM |
Re: Deleting usefull information from the Wiki February 06, 2017 12:54PM |
Re: Deleting usefull information from the Wiki February 06, 2017 01:11PM |
Re: Deleting usefull information from the Wiki February 06, 2017 01:26PM |
dc42
I'm with Arthur on this one - at least in principle, not necessarily with the way it was done which I know nothing about. While I don't think there is necessarily anything wrong with having information on the wiki about how to use closed-source products (e.g. BLTouch) as long as they are clearly flagged as such, I do object to promotion of hardware or software that is a derivative of open-source software and /or hardware (Smoothieboard in this case) but that is in flagrant violation of the open-source license, and therefore a parasite on open source developers.
Re: Deleting usefull information from the Wiki February 06, 2017 01:41PM |
Skimmy
So take the page of the RADDS for example. What is the reason for deleting the whole article, including it's translations?
Re: Deleting usefull information from the Wiki February 06, 2017 02:05PM |
Admin Registered: 18 years ago Posts: 14,142 |
Re: Deleting usefull information from the Wiki February 06, 2017 02:29PM |
VDX
... it seems, there aren't many of the core team "deciders" around to join this discussion
I've reactivated the RADDS page with a (bright) notize on the page and in the talk section to start the discussion about a "reorganization" or categorizing articles between OS and comercial - so this could be the place to get a better view on the current situation ...
Re: Deleting usefull information from the Wiki February 06, 2017 02:46PM |
Re: Deleting usefull information from the Wiki February 06, 2017 03:20PM |
Re: Deleting usefull information from the Wiki February 06, 2017 03:35PM |
toolson
.. and finally my very own opinion:
There should be a rule that is not allowed for commercial active users (examp: arthur/smoothie) to delete or modify entrys by other commercial active users (examp: angelo/radds).
It leaves always a bad baste when this happens.
Re: Deleting usefull information from the Wiki February 06, 2017 03:36PM |
arthurwolf
Accusing me of doing this because I make Smoothieboard is dishonest and outrageous, I was a part of this community long before I started Smoothie ( including in some moderate admin capacities ), and I did not decide anything, just apply a well established wiki ruling. Additionally, quite a few of the Reprap admins have projects and products related to the Reprap project, it's what happens when the same people are active in a project, *and* actually design things, they'll end up both being volunteers and having companies. It's normal. If you think this page shouldn't be deleted that's fine, we can debate that, but accusing me of being dishonest is just not cool. Not cool at all.
It worked
Don't be cross with me.
arthurwolf
This has been marked as Closed-Source and advertising for *well over a year*, with a message saying it would be deleted in march 2016 if the source wasn't released. This is nearly a year later.
arthurwolf
I only applied a well established rule here,
arthurwolf
I didn't decide anything by myself, the page was supposed to be deleted, but the wiki admins don't have enough time to do it all, so I took care of it, that's it.
Because of my position both as a volunteer and as the creator of Smoothie, I actually take great care of what i do on the wiki, and I try to only apply rulings others have made, or when I actually take a decision by myself, I make sure I have a lot of data and thinking backing me up.
arthurwolf
Closed source hardware has nothing to do on the reprap wiki,
arthurwolf
this has been long established by this community ( search the forums ), the reprap wiki isn't for advertising closed-source stuff, even if it happens to be compatible.
arthurwolf
The project even has an extremely liberal definiton of what Open-Source is.
Most companies, states, projects, associations, the UN, etc, have a definiton of Open-source similar to [www.oshwa.org] but the Reprap wiki goes as far as just saying "sufficent to make a copy" ( if it forbids you from selling it, or modifying it, that's ok apparently, which I find dumb as hell, but that's another subject ). That's incredibly wide and permissive definiton. If a project can't fit a criteria this wide, it doesn'vt have it's place on the Wiki of a major Open-Source project.
arthurwolf
Closed source projects can document their stuff on their own website. Any useful information you want to find, you can find there, you know how to use Google.
Putting it on the Reprap wiki if it's not a part of the community effort, just means it's advertising, and that's not what the Reprap wiki is for ! The reprap wiki is documentation for the reprap project, and the community of volunteer's efforts. It's for Open-Source stuff by Open-Source folks.
arthurwolf
The wiki rules say if it's not open-source, it gets a warning, and if it doesn't become/prove it is open-source, it gets deleted. The page has been around for this long only because the admins are too busy to apply all the rules. You just got used to something that was supposed to be temporary. Now that has been fixed. End of story.
arthurwolf
This is the Reprap project, if this is upsetting you, you probably just don't understand what Open-Source is, and how the project came to be.
Re: Deleting usefull information from the Wiki February 06, 2017 04:03PM |
Admin Registered: 15 years ago Posts: 730 |
example warning text on wiki
It appears that the only edits you are making to the wiki are to add links to your business. This contributes nothing of value.
Furthermore, when you add commercial links in the middle of non-commercial projects it significantly devalues the wiki, such as this edit you made to the Delta page.
Please do not add commercial links to a page unless there is already a well established section of that page with the express purpose of listing commercial links.
Re: Deleting usefull information from the Wiki February 06, 2017 04:11PM |
Skimmy
Not accusing. Getting you in this thread with a provoking statement was what I didQuote
arthurwolf
Accusing me of doing this because I make Smoothieboard is dishonest and outrageous, [...] Not cool at all.It worked
Skimmy
Who wrote that message and based on what rule?
Skimmy
That is decided by who? The Community? Guess why this thread is open?!
Skimmy
collected information is not advertising.
Skimmy
Like I stated above, we are far beyond rerprap-style. This would be right at 2007. But we are at 2017... Ten years later.Quote
arthurwolf
Skimmy
The wiki is a part of the biggest 3d-printing community and should reflect their interest.
Skimmy
Please share these rules.Quote
arthurwolf
Skimmy
Sure I understand. And I have an oppinion. And again, this forum, this community here is more than reprap-only since years. It is time for a little adjustment.Quote
arthurwolf
Re: Deleting usefull information from the Wiki February 06, 2017 04:16PM |
Re: Deleting usefull information from the Wiki February 06, 2017 04:18PM |
MattMoses
Regarding the pages up for deletion, it is my personal opinion that they should have a big notice saying "not open source" but they should not be deleted. There are indeed vendors that provide terrible support for their products, and then rely on reprap.org for free advertising and free tech support. It is not fair that closed-source parasite companies can get as much free resources from reprap.org as open-source symbiotic companies. However, sometimes a compromise must be made and we have to tolerate unfairness until something better can be worked out.
We want reprap.org to be useful. So if that means compromising sometimes and keeping useful information on the wiki, even if it relates to non-open-source products, then so be it.
Re: Deleting usefull information from the Wiki February 07, 2017 05:39AM |
Admin Registered: 14 years ago Posts: 2,569 |
Re: Deleting usefull information from the Wiki February 07, 2017 05:55AM |
DeuxVis
I feel a bit awkward about deleting anything that people took some time to contribute, because I respect other people work and time, even when I don't especially need / enjoy it.
If we need to, I'd be ok with removing non open source products information from the wiki provided that :
- We clearly state that rule on a page any new wiki users cannot miss to read => warn people not to waste their time.
- The existing information which can help users exists somewhere else.
- We replace the deleted content by a link to the external location of that information.
Re: Deleting usefull information from the Wiki February 15, 2017 11:12AM |
Re: Deleting usefull information from the Wiki February 15, 2017 11:38AM |
MattMoses
Hi arthurwolf,
Please do not remove any additional information on your competitors' products (or any other information, for that matter) from the wiki until the rules issue is sorted out.
MattMoses
I reverted your recent edits on the RADDS and AZSMZ_Mini pages. I also felt it necessary to protect these pages because you have reverted not only my edits but also those of another admin (VDX).
MattMoses
Please allow me to make a few observations:
1. The wiki still does not have a clear and public policy regarding when pages should be deleted.
MattMoses
So even if a page is advertising (or "not open source" or whatever), we can't point to a rules page that says they should be deleted.
MattMoses
2. Earlier in this conversation you indicated that such rules "are in the forum, and not difficult to find." I asked you to support this claim, but you have not done so. I am not aware of any official rules regarding advertising on the wiki, and personally I don't think such rules exist at this point. We need to agree on and publish the rules before we go around deleting pages.
MattMoses
3. You are deleting pages that describe your competitors' products, so you clearly have a conflict of interest here.
MattMoses
Just for the record: I do not care if RADDS and AZSMZ_Mini are ultimately removed from the wiki. However, we must develop and publish a consistent policy before doing so.
Re: Deleting usefull information from the Wiki February 15, 2017 02:27PM |
Re: Deleting usefull information from the Wiki February 15, 2017 02:51PM |
VDX
... there weren't many of the core team members active or around - on the admins mailing list only Adrian answerd my "who's there alive" post.
So it seems, we have to discuss this in a much smaller group now ...
Re: Deleting usefull information from the Wiki February 16, 2017 05:34AM |
VDX
Re: Deleting usefull information from the Wiki February 16, 2017 10:14AM |
Re: Deleting usefull information from the Wiki February 16, 2017 11:06AM |
VDX
Who's responsible now for the lists and the forums software?
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Deleting usefull information from the Wiki February 16, 2017 12:24PM |
Re: Deleting usefull information from the Wiki February 18, 2017 03:05AM |
Re: Deleting usefull information from the Wiki February 18, 2017 08:02AM |
Re: Deleting usefull information from the Wiki February 18, 2017 02:39PM |
Re: Deleting usefull information from the Wiki February 20, 2017 01:51AM |
