Kennt jemand die "PRINTinZ Printer Plate"?
23. May 2014 05:52
Re: Kennt jemand die "PRINTinZ Printer Plate"?
23. May 2014 07:30
irgendwie beisst sich da war:
#1 ABS und die Temperatur:
er spricht von PLA und ABS, erwähnt aber dann: "up to 70 degrees celsius"
hält ABS bei der Temperatur?
#2 das Video ist geschnitten wenn er das Adafruit von der Platte holt, suspect
Platte $42 dazu dann die Versandkosten, >$30 + Einfuhrumsatzsteuer ca 20%
dann kommt die 20 X 20 Platte schnell mal auf über €60
Dann lieber Willy´s bewährte.
Grüße
seefew
23. May 2014 08:42
Ich hab ja die von Willi, Trotzdem beleibe ich neugierig grinning smiley
Achim
23. May 2014 09:46
Guten Tag,
Sprechen Sie Englisch? Ich kann Fragen über die Platten für Sie beantworten ...
Wayne
PRINTinZ.com
Wayne
PRINTinZ.com
23. May 2014 11:28
Hi Wayne
great to see you´re here.
I´m a little confused about the Video.
They´ve spoken: "up to 70° Celsius"
I thought the heated bed needs about 100° C for to print ABS?
Regards
seefew
23. May 2014 11:51
I've sold many more of these plates since the videos were made and have learned alot. People who have tried printing ABS on this plate at close to 100C have too much adhesion. So they use lower temperatures than what is needed to print on blue tape. Some people have even printed small ABS parts (and nylon) without heat. I have an Afinia printer which doesn't give me any control over the bed temperature. I tell it I'm printing ABS and it heats the machine bed to about 105C. This results in about 70-80C on the top print surface of my plate. This works well on my machine. But if I could lower that temperature I would.
Wayne
PRINTinZ.com
