I have reached the point where the Arduino software says 'RepRapFirmware is up and running' but can get no further.
I have checked all the connections, soldered the USB connections that weren't soldered, replaced the supplied SD card with one that works, and don't know what to try next.
The M503 request just returns an 'OK' but nothing more. Same with the M105 code. I thought the firmware may need updating but I can't check as the M115 code returns only 'OK'.
When I leave the serial monitor window open, it slowly cycles through the following: "Class web server spinning/ class geodes spinning/ class move spinning/ class platform spinning/ class heat spinning". I can't find any information about what this means or if it's relevant.
Any guidance on what I should be looking for or doing would be much appreciated.
