No signal to extruder motor and no ethernet February 09, 2014 07:25PM |
Re: No signal to extruder motor and no ethernet February 09, 2014 07:49PM |
Re: No signal to extruder motor and no ethernet February 09, 2014 08:29PM |
You could try swapping the x-axis and extruder connectors over on the Duet board, then see if x-axis commands move the extruder motor and vice versa. That will tell you whether the problem is in the cable or the Duet board.
Re: No signal to extruder motor and no ethernet February 10, 2014 03:24AM |
Re: No signal to extruder motor and no ethernet February 10, 2014 04:03AM |
Re: No signal to extruder motor and no ethernet February 10, 2014 05:34AM |
Re: No signal to extruder motor and no ethernet February 10, 2014 05:57AM |
Re: No signal to extruder motor and no ethernet February 10, 2014 06:03AM |
Re: No signal to extruder motor and no ethernet February 10, 2014 06:35AM |
Re: No signal to extruder motor and no ethernet February 10, 2014 06:54AM |
Re: No signal to extruder motor and no ethernet February 10, 2014 08:39AM |
Re: No signal to extruder motor and no ethernet February 10, 2014 11:19AM |
Re: No signal to extruder motor and no ethernet February 10, 2014 06:11PM |
Re: No signal to extruder motor and no ethernet February 11, 2014 03:19AM |
Re: No signal to extruder motor and no ethernet February 11, 2014 04:10AM |
