"Bridge" Filament April 03, 2014 01:04PM |
Re: "Bridge" Filament April 03, 2014 02:28PM |
Re: "Bridge" Filament April 03, 2014 04:10PM |
Re: "Bridge" Filament April 04, 2014 04:16PM |
Re: "Bridge" Filament April 05, 2014 08:27AM |
Polymath
... it will mic up bigger than the 0.5 (nominal) nozzle as there is often some expansion due to the pressure relief once out of the nozzle. On PLA I get 0.62mm for example. Enter this as the nozzle diameter in slic3r too, and you'll get a much more accurate extrusion. (I also use this value as the wall thickness for any single wall test pieces, that way the printer doesn't have to move fast to stretch it or slow to squash it, giving optimum quality I believe)...
Re: "Bridge" Filament April 05, 2014 05:05PM |
Ormerod168
how would your your setup then be in slic3r/print settings/advanced/"Default extrusion width" and "Perimeters"?
