Re: New PSU April 01, 2014 10:48AM |
Re: New PSU April 02, 2014 09:00AM |
The_Ross_
Do you power the RAMPS from the same 30amp PSU? I just purchased my first 3d printer kit and am trying to decide on a PSU. I'd like to power the RAMPS and heat bed from the same PSU but don't want to fry anything in the process. Did you have to take any special precautions with your setup?
Re: New PSU April 02, 2014 09:44AM |
Re: New PSU April 10, 2014 11:44AM |
Re: New PSU April 10, 2014 12:01PM |
Re: New PSU April 10, 2014 01:32PM |
As you are using the new power supply for a month now. How is the fan doing, is it still handle the 14V without problem.Quote
dmould
I've just replaced the PSU with the 30amp unit discussed in another thread. It has a voltage adjustment preset which I've set to give 14 volts on its output. The voltage across the bed heater is now 13 volts. I'll see whether the fan survives, but so far so good. The bed gets to 110 degrees in 6 minutes - which is a huge improvement on the 30 minute plus time I had been experiencing. The PSU is also more compact and quieter.
Re: New PSU April 10, 2014 03:07PM |
Re: New PSU April 11, 2014 02:05PM |
Chaisaeng
dmould
Re: New PSU April 12, 2014 03:17AM |
Re: New PSU April 14, 2014 03:12PM |
Pointy
Nice work Dave,
Nice thinking about the 4 pole connector, I wish I had thought of that, although the dimensions and fixings look very close to the Neutrik one, so maybe I could swap if needed.
I have just starting printing my cover for the second time, I had to make a few changes. (I forgot to allow the thickness for the holes, so they are 2mm out and I have shaped it more to stop blocking some of the vents).
I'll post mine here too in case anyone is interested, once I have verified it.
Couple of questions?
- Why 3mm thick? I find 2mm is pretty rigid.
- How long did yours take to print?
Regards,
Les
Re: New PSU April 15, 2014 04:20AM |
Re: New PSU April 15, 2014 07:51AM |
Chaisaeng
I brought a LED power supply intended to use for powering my ormerod.
Some how the one i got after dial up the pot i got max 12.7 V which is a lot less than yours.
(See the attach picture). Any way it was rated at 12v 350w. Is it having issue if i use it for ormerod.
Can it perform better than the supplied ATX power supply?
Re: New PSU April 15, 2014 08:14AM |
Re: New PSU April 15, 2014 11:06AM |
