Part Number For 6 Pin Connector? April 15, 2014 11:54AM |
Re: Part Number For 6 Pin Connector? April 15, 2014 12:45PM |
Re: Part Number For 6 Pin Connector? April 15, 2014 01:24PM |
dc42
[shameless plug] Les, I can't help you with that part number, however if you use one of my Ormerod sensor boards kit 3 or above then you don't need it. My board uses Molex connectors for all the hot end connections, which are much more easily dismantled, and in my experience, more reliable. The connectors are soldered to be board rather than floating in mid air. See [forums.reprap.org] for prices and [miscsolutions.wordpress.com] for more details. [/shameless plug]
Re: Part Number For 6 Pin Connector? April 15, 2014 03:52PM |
Re: Part Number For 6 Pin Connector? April 15, 2014 04:38PM |
Re: Part Number For 6 Pin Connector? April 15, 2014 05:52PM |
Re: Part Number For 6 Pin Connector? April 16, 2014 02:50AM |
Re: Part Number For 6 Pin Connector? April 16, 2014 05:37AM |
Re: Part Number For 6 Pin Connector? April 16, 2014 12:03PM |
Re: Part Number For 6 Pin Connector? April 17, 2014 04:41AM |
Re: Part Number For 6 Pin Connector? April 17, 2014 04:48AM |
Pointy
Ok last question for now Ian.
Where do you get your screws, nuts & washers from or does anyone else know a good place to buy sensible quantities from?
Regards,
Les
