Ever since having the Ormerod I've used Skirts to get the filament flowing, and since changing to just using plain glass without tape
I've been using a Brim to help hold the prints in place.... I hate to think of the number of times the Skirt hasn't stuck properly then got carried in to the print.
Most of the time I've been able to drag it out quick before it's done any harm......
Then this morning it dawned on me.... Why am I using a Skirt AND a Brim.... Doh!
There's no need for the skirt.... If you use a Brim... At worst make the Brim a couple of mm bigger if you have to... I normaly use a 10mm Brim...
Problem Solved.....
It's only taken me a month or so to work that one out....... Brain Dead....
Having gone back to DC's 57Y Firmware I can print again.... If you find your having problems I suggest you migrate back to 57Y as it's pretty good...
Edited 1 time(s). Last edit at 04/21/2014 08:56AM by KimBrown.
