Filament gets stuck all over the nozzle May 07, 2014 03:27PM |
Re: Filament gets stuck all over the nozzle May 07, 2014 04:45PM |
Re: Filament gets stuck all over the nozzle May 07, 2014 05:38PM |
Re: Filament gets stuck all over the nozzle May 07, 2014 06:19PM |
Re: Filament gets stuck all over the nozzle May 07, 2014 07:16PM |
Re: Filament gets stuck all over the nozzle May 07, 2014 07:32PM |
Re: Filament gets stuck all over the nozzle May 07, 2014 10:15PM |
Re: Filament gets stuck all over the nozzle May 08, 2014 01:08AM |
Re: Filament gets stuck all over the nozzle May 08, 2014 02:16AM |
appjaws1
.. lower nozzle so that a piece of normal copy paper just slides in and out under the nozzle, issue G92 Z0..
Re: Filament gets stuck all over the nozzle May 08, 2014 02:42AM |
Re: Filament gets stuck all over the nozzle May 08, 2014 04:07AM |
ormerod168
appjaws1
As the slicer program expect zero to be absolute it would be more appropriate to zero on nothing, but nothing is hard to handle and find in the toolbox when needed (the upside here is that nothing is lost) the only findable close to nothing-thing I can think of is household aluminum foil at 0.011 mm - and fingerspitzgefühl, lots of it
Erik
dc42
I had a similar problem when I was a few tens of metres into a new reel of filament. Eventually I switched to another reel from a different supplier and the problem went away.
Re: Filament gets stuck all over the nozzle May 08, 2014 05:43AM |
Re: Filament gets stuck all over the nozzle May 08, 2014 05:52AM |
Re: Filament gets stuck all over the nozzle May 08, 2014 06:13AM |
Cant hear a bloody thing over the sound of the fanQuote
aesuli
Check if you can hear small popping sounds from the nozzle due to the evaporating humidity.
aesuli
How "old" is your spool of filament?
I have experienced the same problem toward the end of a 1KG spool, and it was likely due to the PLA having absorbed humidity along time.
With a new spool the problem was gone.
Re: Filament gets stuck all over the nozzle May 08, 2014 08:33AM |
Re: Filament gets stuck all over the nozzle May 08, 2014 09:01AM |
dmould
While the nozzle is about 0.1mm above the bed when it first touches the paper, it must be lower in order to put pressure on the paper to exert the drag you can feel, and that probably just brings it into contact with the bed after the paper is removed.
Dave
(#106)
Re: Filament gets stuck all over the nozzle May 08, 2014 09:37AM |
Sardi
It as if the extrusion of the first few mm of filament is darn slow..
Maybe to add a value to slic3r -> Printer Settings -> Extruder 1 -> Retraction -> Extra lenght on restart? Currently 0.
Re: Filament gets stuck all over the nozzle May 08, 2014 10:02AM |
Altough that is something I can live with, that also sometimes creates a wreck of my print, because on return, the ball of filament sticks to the hot head and starts sticking to all other filament like its collecting coins in a game.Quote
dmould
It's normal that the start of the first loop of the skirt doesn't print.
dmould
If you set Slic3r to extrude filament before the start as you suggest, you'll be dragging a length of extrusion around, which could get tangled in the print. The dribble that comes out when the extruder heats is bad enough without adding more!
Re: Filament gets stuck all over the nozzle May 08, 2014 10:37AM |
Re: Filament gets stuck all over the nozzle May 08, 2014 10:46AM |
Re: Filament gets stuck all over the nozzle May 08, 2014 10:52AM |
I am leaving that for last, dont want to open a new reel only to find out its not the filaments fault.Quote
dc42
Two suggestions, apart from trying different filament:
If I lower it by 0.1 it will just grasp the paper I use for bed leveling, any lower than that and its in the bed.Quote
dc42
1. Try a slightly lower z=0 height. I use the web interface set to half z steps so that I can set the height to within 0.05mm.
Dont have it, will go and buy it.Quote
dc42
2. Try printing on glass coated with solvent pipe cement. I have never has adhesion problems this way.
KimBrown
Hi Sardi, 80/85' is to hi for PLA.... I've found allot of time that anything more than 60/65' causes the plastic on the first layer to blister and lift, which causes your problem. It then tangles around the IR probe, and eventualy around the HotEnd...
Now I use 57' and it seems good. The first layer temp seems dependant of the filament I use.... Normaly I use 195/215', and found it quite critical.
If it still doesn't stick I lower the head by 0.1mm till is does, provided the bed is level.
Kim..
Re: Filament gets stuck all over the nozzle May 08, 2014 11:35AM |
Re: Filament gets stuck all over the nozzle May 08, 2014 11:54AM |
Re: Filament gets stuck all over the nozzle May 08, 2014 11:59AM |
droftarts
We print on Kapton, we find it's the most reliable, and least maintenance once set up. Having the bed clean is imperative, as is the first layer height. Also, bed temperature should not be higher than around 66C maximum, or PLA will be too soft and pull back off.
droftarts
Who told you to set the bed temperature to 75C?!
Re: Filament gets stuck all over the nozzle May 08, 2014 12:10PM |
Re: Filament gets stuck all over the nozzle May 08, 2014 12:55PM |
Re: Filament gets stuck all over the nozzle May 08, 2014 01:38PM |
Re: Filament gets stuck all over the nozzle May 08, 2014 01:41PM |
Re: Filament gets stuck all over the nozzle May 08, 2014 02:59PM |
