New web interface software 0.75 released May 10, 2014 07:10AM |
Re: New web interface software 0.75 released May 10, 2014 07:14AM |
Re: New web interface software 0.75 released May 10, 2014 07:35AM |
Re: New web interface software 0.75 released May 10, 2014 07:52AM |
Re: New web interface software 0.75 released May 10, 2014 08:22AM |
Re: New web interface software 0.75 released May 10, 2014 11:35AM |
Re: New web interface software 0.75 released May 10, 2014 01:39PM |
Re: New web interface software 0.75 released May 10, 2014 02:00PM |
Re: New web interface software 0.75 released May 10, 2014 03:35PM |
dc42
Bob, I agree. The firmware already supports uploading other files, so the work needs to be done in the web interface. Maybe Matt will have time to do this soon, he's better at web/javascript code than I am.
Re: New web interface software 0.75 released May 12, 2014 03:14PM |
Re: New web interface software 0.75 released May 12, 2014 04:16PM |
Re: New web interface software 0.75 released May 12, 2014 09:02PM |
Re: New web interface software 0.75 released May 13, 2014 08:34AM |
dc42
Hi VortyZA, there have been a couple of reports of this problem, although not since I released 0.59. Please check the following:
* Are you running the 0.59 release of my firmware? If you are running a 0.58 or a 0.59 beta version, please upgrade.
dc42
* Before uploading, run the command M111 S2 and look at the response in the message log, in particular the "Free file entries" value. It should normally be 10, but may be 9 if you have paused or abandoned a print. If it is close to zero, then reset the Duet. If you ever discover a way to get it to fall below 9 other than momentarily, please let me know how.
Re: New web interface software 0.75 released May 13, 2014 08:57AM |
FIRMWARE_NAME:RepRapFirmware FIRMWARE_VERSION:0.59-dc42 ELECTRONICSuet DATE:2014-05-08
Re: New web interface software 0.75 released May 14, 2014 10:00AM |
Re: New web interface software 0.75 released May 14, 2014 10:30AM |
Re: New web interface software 0.75 released May 14, 2014 10:45AM |
Re: New web interface software 0.75 released May 14, 2014 02:13PM |
Pointy
I had to switch it off quick as it tried to print without any heaters on!
Strange how its just affects a couple of files though.
Re: New web interface software 0.75 released May 14, 2014 02:19PM |
dc42
Pointy
Found the problem. Rename the file before uploading so that the filename does not contain an uppercase G. This affects all firmware versions, both mine and official RRP ones. Will fix in 0.59a.
Re: New web interface software 0.75 released May 14, 2014 02:22PM |
Re: New web interface software 0.75 released May 14, 2014 03:39PM |
Re: New web interface software 0.75 released May 15, 2014 05:36PM |
