Bent y motor mount problem May 15, 2014 04:15AM |
Re: Bent y motor mount problem May 15, 2014 06:52AM |
Chaisaeng
...The belt tension pull it so it will be seen prominently while it still installed in the printer.
Anyone having idea to reinforce it so it will stay square with few effort.
Re: Bent y motor mount problem May 15, 2014 06:57AM |
Re: Bent y motor mount problem May 15, 2014 07:02AM |
Re: Bent y motor mount problem May 15, 2014 02:11PM |
Re: Bent y motor mount problem May 15, 2014 03:18PM |
Chaisaeng
Thanks for all suggestion. .I think of something Erik do strengthen on both side of acrylic part
with square aluminum and maybe cutting another square aluminum for motor mount.
Re: Bent y motor mount problem May 16, 2014 08:19AM |
Chaisaeng
Re: Bent y motor mount problem May 16, 2014 08:21AM |
Re: Bent y motor mount problem May 16, 2014 09:30AM |
dmould
Quite possibly the unmodified part printed in ABS instead of PLA would be sufficient. ABS won't get soft due to the motor getting hot, and I think it is also a stronger plastic.
Dave
(#106)
Re: Bent y motor mount problem May 16, 2014 09:51AM |
