Printing on Glass May 11, 2014 05:46AM |
Re: Printing on Glass May 11, 2014 06:24AM |
Re: Printing on Glass May 11, 2014 07:53AM |
Re: Printing on Glass May 11, 2014 09:06AM |
Re: Printing on Glass May 11, 2014 09:15AM |
Re: Printing on Glass May 11, 2014 09:27AM |
KaGen101
I wait about 5-10mins after print and then it just comes off. It comes of remarkably easy in comparison to things on the Kapton tape....
It is like when the hair spray cools again then the bond wants to disengage...you can also spray some PC Duster or similar product on it but the wait has never been that long.
Re: Printing on Glass May 12, 2014 08:02AM |
Form232-tek
I print directly to the glass, but without hairspray or anything else. I just clean the glass very carefully before i start.
Re: Printing on Glass May 12, 2014 10:43AM |
Re: Printing on Glass May 13, 2014 08:23AM |
KaGen101
The green neon heads in the photo attached where printed like this on glass as is.
As a matter of fact it sticks at much lower temps:
85C first 5 layers then drop the heat down to 50C so the ABS don't warp
Works brilliantly with ABS. Actually tried it on that first and then PLA
Re: Printing on Glass May 13, 2014 10:19AM |
dmould
KaGen101
Are you saying that you printed ABS onto plain glass? In your first post you said you used hairspray. I found hairspray works OK with ABS, but the ABS/acetone solution is better & cheaper. My understanding is that a cooler bed is more likely to increase warping rather than reduce it. The ABS will stick to cold glass coated with my ABS/acetone solution and is fine for a few layers, but will tend to lift on later layers if the bed is kept cold.
Dave
(#106)
Re: Printing on Glass May 13, 2014 10:30AM |
VortyZA
I've had the same results as Dave - cooling the bed after a few layers made it more likely for the ABS to come away during the print. I use both Kapton tape and ABS juice and find the print can then be done at 85C bed temperature.
The thicker the ABS parts, the more it will contract towards itself, so even with the Kapton tape and ABS juice I've had thick parts that tried very hard to pull off and after the print is complete there is an outline of the shape in small bubbles in the Kapton tape!
Re: Printing on Glass May 16, 2014 12:25AM |
Re: Printing on Glass May 16, 2014 01:28AM |
Re: Printing on Glass May 16, 2014 03:12AM |
Re: Printing on Glass May 16, 2014 08:56AM |
VortyZA
That being said, I have one specific part that I *cannot* print without it pulling off the bed even with Kapton tape and ABS juice.
What sort of ratio of ABS to acetone do you use? How thickly do you apply it?
If I'm printing that part I have to baby it for the first 10 layers or so, 'gluing' the part down if it starts lifting off the bed with a generous portion of juice! It tends to pull off proportionately no matter the orientation of the part, so it's got to do with the design I'm sure.
I've even tried adding 'anchor' parts to remove afterwards that have nice round bases, but those pull away too!
Re: Printing on Glass May 16, 2014 01:59PM |
dmould
VortyZA
Have you tried printing with a raft? If it lifts after only a few layers, it's likely that the extruder is the wrong height on that part of the first layer. Too high and it won't stick properly, a bit too low is good, but if excessively low the layer has very thin "lean" spots that also don't stick well (easily seen). Warping doesn't usually start occurring until the print is at least 5mm high.
I don't measure the solution strength. When the jar starts running low I just add a bit of acetone and about an eighth or so that volume of ABS - but very approximately judged. I keep scrap prints of white & natural ABS for that purpose, and hack them up with tinsnips. It is still runny like water, and I brush a single coat onto the glass, then check that the whole glass surface looks frosty after it has dried - if not I touch up the shiny bits. If there are too many shiny bits I give the whole glass a re-coat and add a bit more ABS to the solution. Brush onto cold glass and let it dry at room temperature (it only takes a minute or so) before heating on the bed.
Caution - if you spill even a few small drops on your clothes it is difficult to get rid of the stain it leaves. It will eventually come out with repeated soaking in acetone and rubbing with a kitchen towel, but a normal wash won't touch it.
Dave
(#106)
Re: Printing on Glass May 16, 2014 03:06PM |
Re: Printing on Glass May 17, 2014 02:03AM |
dc42
I'm talking about PLA. I have a roll of ABS but I haven't started it yet.
Re: Printing on Glass May 17, 2014 03:34AM |
