Z Setting Question - Microswitch May 20, 2014 01:55AM |
Re: Z Setting Question - Microswitch May 20, 2014 02:29AM |
Yes this should be possible and work similar to your CNC, on my printer " a clean head, with no plastic residue" is rarely the case.Quote
robbycar
.... could I just put a terminal onto one of the screws which holds the hotend and connect this to the Duet, and the other Duet lead goes to a metal plate of fixed thickness which can be put out on the bed just to home.
Then when the head goes down, the nozzle will contact the metal plate, complete the circuit and give us a reference point for Z. Of course this would need a clean head, with no plastic residue....
Rob.
Re: Z Setting Question - Microswitch May 20, 2014 02:49AM |
robbycar
For a microswitch used for Z axis, would this be a normally open or a normally closed switch?...
Re: Z Setting Question - Microswitch May 20, 2014 03:16AM |
Re: Z Setting Question - Microswitch May 20, 2014 04:13AM |
