Poor layer adhesion?
Posted by Davek0974
June 13, 2014 11:00AM
I'm running PLA and just printed an enclosure box for a project, the dimensions were 100x100x50mm, split into a lid and base.
Wall and base thickness was 2.5mm, there are corner supports added for the cover screws.
It looks cosmetically great but i'm finding it very easy to split the walls, it appears that the PLA has not "bonded" intermittently??
It was printed at 195c/190c and bed at 65c/60c
First attempt was layer height 0.24mm, which took a while, second attempt was 0.36mm layer height.
I think infill was 40% or slic3r default whatever that was.
Any suggestions?
The last print was usable but you can feel the walls move a bit if stressed.
Another RS Ormerod Mk1 meets the world smiling smiley
Retired now but I used to make....
CNC Machined Mk1 aluminium bed support plates for the Ormerod
CNC machined X-plates and ribs for Mk1 & Mk2 Ormerods
CNC machined bed support arms for the Mk2 Ormerod.
Dual Hot-End heatsink blocks.
Re: Poor layer adhesion?
June 13, 2014 03:44PM
All prints are relatively weak in the Z direction, and layers will not bond to be as strong as the print is in the XY plane. You should orient your designs with that in mind - it is sometimes better to make an item in two or more pieces so as to get their orientations in the direction that needs the strength, and bolt/glue them together afterwards. You can experiment with different extruder temperatures and maybe block off the cooling air jet. A hotter extrusion will bond better, but also have a greater tendency to warp (which can also cause delamination) and has poorer bridging properties. You can also design in vertical ribs to provide greater strength to side walls - or make the walls thicker in general (though that can also promote warping).
Dave
(#106)
June 13, 2014 04:04PM
Ok, ta, I'll keep messing about.
Is it possible to print with 100% infill I.e. solid ?
June 13, 2014 05:22PM
I had been extruding PLA filament at 190c with great result - very strong. Then I bought a spool from another supplier, and got a very weak bond between the layers. After raising the temperature to 205c, the strencth of the bonds was back.
I'm currently printing some ABS-parts for the Ormerod with 0.95% fill with great results.They are very close to solid. I did not go to 1.0, because I was afraid it would affect the dimensions of the parts.
Please note, that most of the stiffness and strength of the printed parts comes from the perimeters (like in honey-comb plates). Therefore you will not gain much by using 1.0 fill. If you increase the number of perimeters to 6 or 8 on bigger parts, you will get much stiffer parts without using excess filament - not to mention tons of problems with warping. Just remember to increase the number of solid top/bottom-layers as well. This comes from basic static/mechanics calculations.
Best regards,
Carsten
June 14, 2014 03:29AM
Will try that
Thanks
June 14, 2014 05:59AM
Please let us know the results. I was quite surprised how big the difference between the two filaments was.
By the way, your aluminium x-plates are working absolute wonders with my prints.
Best regards,
Carsten
June 14, 2014 10:27AM
If your using a Big Blue I'd suggest you run at a temp of 200' or 205' at the Walls with the Exhaust Pipe Uncovered to reduce the cooling air.
Remember that the second fill in the wall section has to be hot enough to meld with the first perimeter.
When running Pronterface you can actualy raise and lower the HotEnd Temp while printing manualy, as well as control the Fan if you have it connected correctly using the M106 code.
If you have a single Fan on your BigBlue and it's connected to the Secondary Fan pins then don't run it below M106 S70 as you won't have air blowing throu the HeatSink if you reduce it lower.
If you have two Fans the Second one can be set to M106 S0 while doing the walls (M106 S0 turns the secondary Fan off...M106 S255 turns it Full On).
You can also let Slic3r control the fan, but again remember to set the Minimum to around S70 with a single Fan (you might be able to go a little lower dependant on your Fan, but you'd need to feel the HeatSink while it is running to check it is cool).
If your curious about the controlable Fan then it's marked on this Duet Diagram below... (As FAN2). Just move the fan wires over, but do check your Slic3r settings if you do this.... Else you might find the fan is turned off and the Ormerod would look very strainge with the HotEnd whipping around, slowly melting..... smiling smiley
Edited 1 time(s). Last edit at 06/14/2014 10:31AM by KimBrown.
June 14, 2014 12:16PM
Trying 4 perimeters and 4 solid top and bottom layers now.
I have not ventured into the big blue arena yet, I'm still running the standard z head with noisy fan sad smiley
June 14, 2014 12:51PM
hihihihi in the Big Blue I suggest to people to use rubber 'o' rings to rubber mount the fan/s.
If using two fans like I do, one sits ontop of the other to give it that extra puff of air when needed....
And Big Blue bridges in 360' not just up and down the X axis... smiling smiley
If I stick with the Ormerod, which I probably will, I maybe doing an even better version in the coming months. But it's good as is for now...
