Dual Hot-End Heatsink Blocks.... July 14, 2014 04:24AM |
Re: Dual Hot-End Heatsink Blocks.... July 14, 2014 04:52AM |
Re: Dual Hot-End Heatsink Blocks.... July 14, 2014 05:09AM |
Re: Dual Hot-End Heatsink Blocks.... July 14, 2014 05:24AM |
Re: Dual Hot-End Heatsink Blocks.... July 14, 2014 05:41AM |
Re: Dual Hot-End Heatsink Blocks.... July 14, 2014 06:34AM |
Re: Dual Hot-End Heatsink Blocks.... July 14, 2014 06:40AM |
Re: Dual Hot-End Heatsink Blocks.... July 14, 2014 05:13PM |
Re: Dual Hot-End Heatsink Blocks.... July 14, 2014 05:32PM |
Re: Dual Hot-End Heatsink Blocks.... July 15, 2014 02:30AM |
Re: Dual Hot-End Heatsink Blocks.... July 15, 2014 05:16AM |
¨Quote
dc42
It wasn't hard to get the two nozzles at close to the same height during assembly of my dual nozzle head. Fine adjustment is possible by adjusting the relative tension on the two nozzle mounting screws. With 3 in-line nozzles, it would be important to get the 3 tips in the same plane, but that would be very easy to check during assembly.
I really don't see any need for the complexities of water cooling with a 2-head nozzle, although I concede that it might make sense for the 4-head Kraken. The main problem I see with the Kraken is the huge number of cables it needs. It would make more sense to control the heaters using a dedicated microcontroller mounted on the hot end, then you would need only 2 (thick) power conductors and 3 signal conductors between the Duet and the hot end.
Re: Dual Hot-End Heatsink Blocks.... July 15, 2014 08:47AM |
Joar107
I agree it would be great to get rid of some cables, wouldnt this be great on the "original" solution as well?
Re: Dual Hot-End Heatsink Blocks.... July 15, 2014 02:25PM |
Re: Dual Hot-End Heatsink Blocks.... July 15, 2014 02:28PM |
Joar107
¨Quote
dc42
I did a quick model of "ormken" the 3 headed kraken for ormerod it measure 60 x 23 x 20
[attachment 36602 orkan_ormerod.JPG]
[www.dropbox.com]
Re: Dual Hot-End Heatsink Blocks.... July 17, 2014 08:45AM |
Re: Dual Hot-End Heatsink Blocks.... July 17, 2014 08:48AM |
Re: Dual Hot-End Heatsink Blocks.... July 17, 2014 11:17AM |
Re: Dual Hot-End Heatsink Blocks.... July 17, 2014 11:33AM |
dmould
Hmmm - won't the plastic melt being that close to the heat blocks ...
Re: Dual Hot-End Heatsink Blocks.... July 17, 2014 11:37AM |
dmould
Dave
(#106)
Re: Dual Hot-End Heatsink Blocks.... July 17, 2014 11:54AM |
Re: Dual Hot-End Heatsink Blocks.... July 17, 2014 02:25PM |
ezwul
Davek
When will the Dual Hot-End heatsink blocks be available?
Lloyd
Re: Dual Hot-End Heatsink Blocks.... July 17, 2014 02:26PM |
dc42
I've come to realise that it would be better to increase the spacing between the nozzles. The disadvantages of increased nozzle spacing are that small changes in head angle in the X direction affect the relative height of the nozzles more (if that is a disadvantage), and the 2-colour print area is slightly reduced. The advantage is that in prints for which the non-printing nozzle passes over a recently-printed area (e.g. the traffic cone), the time between the printing and non-printing nozzles passing the same area will generally be increased, giving more time for the filament to cool in between. This cooling time is vital.
So my new dual nozzle design is based on my existing one (with the nozzle mounting screw holes outside the heatsink screw holes as before), but with the nozzle hole spacing increased to 22mm. I think that leaves just enough clearance (5mm) between the nozzle holes and the heatsink screw holes. I will turn the heater blocks over to avoid increasing the overall width. If a 3rd nozzle hole is included in the centre, then the same design can also be used for a single-nozzle hot end that fits the same nozzle mount.
DaveK, may I order a couple?
Re: Dual Hot-End Heatsink Blocks.... July 17, 2014 05:20PM |
Re: Dual Hot-End Heatsink Blocks.... July 17, 2014 06:19PM |
Davek0974
Of course, can you give me a checked sketch of your design please if you are moving to new measurements.?
Re: Dual Hot-End Heatsink Blocks.... July 18, 2014 03:11AM |
ezwul
I am interested in experimenting with this as well, can you let me know the price?
Lloyd
Re: Dual Hot-End Heatsink Blocks.... July 18, 2014 03:13AM |
dc42
Davek0974
Sure, here it is. The distance between the M5 and M3 tapped hole centres is 5mm, which I hope is enough as it should leave at least 1mm of solid metal between them where they cross.
Re: Dual Hot-End Heatsink Blocks.... July 18, 2014 04:07AM |
Re: Dual Hot-End Heatsink Blocks.... July 18, 2014 04:31AM |
dc42
Dave, I've decided to go for separate 1- and 2-nozzle designs, for better heat transfer (and this will reduce the amount of drilling and tapping you need to do). Here is the revised design. I'd like one of each please, and I'll send £21 via PayPal shortly.
Re: Dual Hot-End Heatsink Blocks.... July 18, 2014 04:32AM |
Re: Dual Hot-End Heatsink Blocks.... July 18, 2014 05:54AM |
dc42
