Print stops half way twice on the same spot July 24, 2014 03:29AM |
Re: Print stops half way twice on the same spot July 24, 2014 12:05PM |
Re: Print stops half way twice on the same spot July 24, 2014 01:02PM |
Re: Print stops half way twice on the same spot July 24, 2014 01:27PM |
Re: Print stops half way twice on the same spot July 24, 2014 04:47PM |
dc42
Sardi, if the web interface freezes and restarts, then the firmware has probably locked up and triggered a watchdog reset (although I've not heard of that happening before with my 0.65 series firmware). I suggest you upgrade to 0.78e-dc42 available here [github.com] and web interface 0.98 here [github.com], because there has been a lot of change to the movement code since 0.65j. Don't forget to connect the Z probe blue (and white if you have it) wires to their new positions on the expansion connector, see [forums.reprap.org] for details.
