Week 3 Experience and questions August 05, 2014 09:53PM |
Re: Week 3 Experience and questions August 06, 2014 04:39AM |
Re: Week 3 Experience and questions August 06, 2014 04:45AM |
Re: Week 3 Experience and questions August 06, 2014 05:20AM |
Re: Week 3 Experience and questions August 06, 2014 05:49AM |
Yep agreedQuote
dc42
If the device is mounted close to the Duet and powered from it, then using 3.3V TTL signals should be workable. You need to be careful because there may be noise on the ground pin, especially if you have a DueX4 connected as well.
A good project for someone but not my cup of teaQuote
dc42
It might even be possible to get the Panalolu2 working with the Duet, since the TWI pins are brought out both on the Duet expansion connector and the DueX4 expansion connector.
Didnt realy want to dig into the duet firmware that much and make another non standard version (when yours works so well allready)Quote
dc42
Yet another possibility is to have the Duet drive everything directly. A 128x64 GLCD using the ST7920 chip needs only 3 wires to drive it, and a rotary encoder needs only 2. Add 1 if you want a piezo sounder as well. That's 6 signals total. I believe that 20 out of the 22 signals on the DueX4 expansion connector are currently free.
Hmm ok may have to have another look though the source i figured there would be enough there but maybe notQuote
dc42
The protocol used by the web interface provides considerably more functionality than the Gcode interface, so if you decide to go the serial route then duplicating the existing software for handling USB I/O might not be the best way to go.
yeah agree I just used panelolu2 as an example i was thinking something based on a KS0108B maybe Graphic LCD 128x64Quote
dc42
btw a GLCD could look much nicer than the character-based display on the Panalolu2 because you can use different size fonts and proportional spacing.
Re: Week 3 Experience and questions August 06, 2014 06:31AM |
Re: Week 3 Experience and questions August 06, 2014 12:47PM |
