imperfections August 31, 2014 03:51PM |
Re: imperfections August 31, 2014 04:18PM |
Re: imperfections August 31, 2014 05:23PM |
dc42
Blobbing on the first layer typically means either that the filament isn't flowing well yet (in which case you can increase the minimum skirt extrusion amount), or the nozzle is too close to the bed.
Re: imperfections August 31, 2014 05:42PM |
Re: imperfections September 01, 2014 12:39PM |
Re: imperfections September 01, 2014 12:44PM |
gnarly
rechecking the Z plane with the bed at 65 shows that it swells by 0.5mm and is slightly barreled
(no change along the y axis, but curves on the X axis)
Re: imperfections September 01, 2014 06:52PM |
Re: imperfections September 02, 2014 03:53AM |
Re: imperfections September 03, 2014 08:16AM |
gnarly
hmm, I'm using DD Metal Products Al bed, x-rib and x-plate, so that's less likely.
It struck me that if both sides/ends of the bed support and hot plate are rigidly bolted,
then the hot plate will expand more and cause doming...
looking up some numbers...for linear expansion coefficients in 10^-6 m/mK:
Al 22.2
glass 9
Cu 16
Kapton 20
plastics >40
so for 200mm length and say 45 degree rise, we get Al expanding by 0.2 mm with is unhelpfully close to
the tolerances we are trying to work to.
Re: imperfections September 03, 2014 08:32PM |
Re: imperfections September 04, 2014 11:57AM |
Re: imperfections September 13, 2014 10:42AM |
Re: imperfections September 13, 2014 01:38PM |
gnarly
..Having waded through old posts on the forum I decided to tweak the extruder multiplier in slicer...
and set it to 0.9...
and verily...I have my first complete perimeter without blobs
dc42
4. Print not going well? Adjust print speed and extrusion factor on the fly!
You can adjust the print speed on the fly by sending M220 S### where ### is the percentage of the normal print speed you want. For example, M220 S50 will print at half speed. You can’t override the maximum speeds with M220, you’ll need to use M203 to do that.
Similarly, you can adjust the extrusion factor by sending M221 S### where ### is the percentage of the normal extrusion amount that you want.
Even if you can’t save your current print with these commands, by experimenting with different values during a single print, you may be able to determine the optimum speed and extrusion factor for when you restart the print. Bear in mind that if you adjust the extrusion factor using M221, then the print end time estimated from filament consumption will be inaccurate.
