Printing with PLA, temperature? September 14, 2014 11:18AM |
Re: Printing with PLA, temperature? September 14, 2014 11:38AM |
Re: Printing with PLA, temperature? September 14, 2014 06:59PM |
Re: Printing with PLA, temperature? September 15, 2014 08:46AM |
Re: Printing with PLA, temperature? September 16, 2014 04:58PM |
Re: Printing with PLA, temperature? September 17, 2014 07:49AM |
Aagaard
Allright. I guess I'll have to buy a thermocouple thermometer. And repeat the investigation. Ebay here I come!
Thanks for your thoughts!
Re: Printing with PLA, temperature? September 17, 2014 11:12AM |
dmould
..Get one that comes with a long wire thermocouple probe that..
[forums.reprap.org]Quote
dmould March 10, 2014
I used a thermocouple thermometer (RS part number 206-3722) The K type thermocouple that comes with the instrument has a lead that is long enough and thin enough to fit down the bowden tube. I removed the filament, took the bowden tube out of the extruder and fed the thermocouple down the tube till it bottomed in the molten plastic left in the nozzle, so the reading is about as accurate as you could get. IR thermometers are not going to be reliable because (1) the target area is a lot smaller than the spot size for most instruments and (2) the aluminium has poor IR emissivity, which is going to give extremely unreliable readings unless you know exactly what correction factor to apply.
Obviously any thermocouple thermometer should work - some multimeters have a thermocouple input. Perhaps your digital stake thermometer will take other types of thermocouple in which case just get a thermocouple that will fit down the tube (such as RS 787-7709).
Dave
(#106)
