solution to 2 nozzle height adjustment September 08, 2014 08:51AM |
Re: solution to 2 nozzle height adjustment September 08, 2014 09:32AM |
Re: solution to 2 nozzle height adjustment September 09, 2014 10:46AM |
Re: solution to 2 nozzle height adjustment September 10, 2014 04:23AM |
dmould
Maybe a spring instead of a lock nut would do the trick?
Dave
(#106)
Re: solution to 2 nozzle height adjustment September 10, 2014 08:47AM |
Re: solution to 2 nozzle height adjustment September 10, 2014 09:44AM |
ezwul
With your Design, have you had any problems with the fan duct?.
ezwul
Presumably the head is adjusted to make the nozzles level, which is dependant on how well the match is between the hot ends after they are screwed into the heatsink. .
ezwul
If the nozzles are now parallel to the bed this presumably means the heatsink and nozzles on the underside of the fan duct are also slightly off level (one side higher than the other)?
Presumably this difference is so small it is negligable compared to the 1-2mm the fan outlets are above the heated nozzles..
ezwul
What is your procedure for levelling?
Do you loosen both bolts.
Lower the head assembly allowing the heads to naturally level out on the bed
Tighten the screws to hold the head level or another method?.
ezwul
Another thought, the hot bed must be mechanically level otherwise the nozzles will be out at different points on the bed(sloping bed), so not a good idea to use auto bed compensation, unless the nozzles are adjusted over the same place on the bed (to within a few mm).
ezwul
Sorry brain is racing through all sorts of scenarios, just wondering if you have seen any of this affect your prints or if I am over complicating the setup..
ezwul
P.S. Did you post both parts of the new head assembly above or the same part twice, good design though.
Re: solution to 2 nozzle height adjustment September 10, 2014 10:02AM |
Re: solution to 2 nozzle height adjustment September 21, 2014 01:49PM |
Re: solution to 2 nozzle height adjustment September 21, 2014 02:10PM |
