Ormerod 2 commissioning issue: vibrating stepper motors November 05, 2014 06:45PM |
Re: Ormerod 2 commissioning issue: vibrating stepper motors November 05, 2014 08:15PM |
Re: Ormerod 2 commissioning issue: vibrating stepper motors November 06, 2014 04:51AM |
Re: Ormerod 2 commissioning issue: vibrating stepper motors November 06, 2014 04:57AM |
Re: Ormerod 2 commissioning issue: vibrating stepper motors November 10, 2014 12:49PM |
Re: Ormerod 2 commissioning issue: vibrating stepper motors November 11, 2014 04:52AM |
tstone
I had also issues with the z-axis motor and the y-endswitch. Replaced the y-endswitch but then i realized that the connector
problems can be fixed rather easy. Use a thin metal piece to push against the metal hook holding the pin inside of the
female connector. When pushed right you can remove the metal piece which should do the contact. Bend this metal piece
open so that it fills out the whole hole, push it back in until it sits again in its place. Repeat with every pin.
Re: Ormerod 2 commissioning issue: vibrating stepper motors November 11, 2014 08:20PM |
