fluctuating hot end temperature November 18, 2014 10:00AM |
Re: fluctuating hot end temperature November 18, 2014 02:32PM |
Re: fluctuating hot end temperature November 19, 2014 08:37AM |
dc42
May I assume you are running a single nozzle hot end, or you are referring to the first nozzle on a dual nozzle hot end? There are temperature reading errors for additional thermistors connected to a DueX4 expansion board..
dc42
1. S factor set too low when using my or zpl's firmware, so that the head cannot maintain temperature at maximum allowed power..
dc42
2. A bad connection in the hot end heater wiring. Check all crimp connections and pin/socket pairs for scorching..
dc42
3. Ditto but on the Duet. Someone reported this kind of problem recently in another thread..
dc42
4. If you are using one of my hot end boards and the +3.3V or ground connection is lost, this may affect the temperature readings. Again, check the crimp connections..
dc42
Try setting the hot end to 200C, wait for it to settle, then waggle the hot end loom to see if you can make the reading change.
Re: fluctuating hot end temperature November 19, 2014 09:01AM |
Re: fluctuating hot end temperature November 19, 2014 09:10AM |
Re: fluctuating hot end temperature November 19, 2014 10:46AM |
zombiepantslol
Paul, I suggest you ensure your M304 parameters are okay. Have a look at this: [forums.reprap.org]
Re: fluctuating hot end temperature November 19, 2014 10:51AM |
Re: fluctuating hot end temperature November 19, 2014 12:00PM |
Thanks for the reply.Quote
zombiepantslol
Yes sorry, I meant to say M305. I believe the code for ADC offsets changed some time ago... Do you have a chance to adjust your parameters with a few resistors?
Re: fluctuating hot end temperature November 19, 2014 02:06PM |
Re: fluctuating hot end temperature November 19, 2014 02:12PM |
Re: fluctuating hot end temperature November 19, 2014 02:36PM |
dc42
Hi Paul, sorry to hear you have damaged your board. However, if the damage is in the area of R22 (which is not fitted) then it means you connected the 12V supply wires the wrong way round, and the board can be repaired by replacing the diode and mosfet in that area. You can do this yourself, or send the board back to me and I will do it for £10+vat.
Re: fluctuating hot end temperature November 19, 2014 06:39PM |
dmould
Aren't they used only for the fan control? If so the fan can be wired permanently on, with the damaged components removed (in case they have failed in short-circuit) but not replaced.
Dave
Re: fluctuating hot end temperature November 20, 2014 02:48AM |
Re: fluctuating hot end temperature November 20, 2014 10:33AM |
dc42
dmould
Dave
Yes, in fact the unpopulated R22 position is there so you can connect a 0 ohm resistor (or wire link) to bypass the fan control, as on the Kit 2 variant of my original board. So one option is to remove the diode and the remains of the mosfet, and then put a wire link across R22.
Re: fluctuating hot end temperature November 20, 2014 11:08AM |
Re: fluctuating hot end temperature November 21, 2014 07:56AM |
Re: fluctuating hot end temperature November 21, 2014 08:12AM |
Re: fluctuating hot end temperature November 21, 2014 08:17AM |
Re: fluctuating hot end temperature November 21, 2014 08:51AM |
Re: fluctuating hot end temperature November 21, 2014 09:23AM |
Re: fluctuating hot end temperature November 21, 2014 09:31AM |
; M304 S1.0 ; bed heater - no need for this line, because the hot bed isn't driven by PWM M301 S0.9 ; extruder 1 (no need for H1) M301 H2 P1 S0.9 ; extruder 2 (needs H2 for third heater) M305 P0 Hxx Lxx ; bed heater (M305 always requires P parameter, i.e. heater index) M305 P1 Hxx Lxx ; extruder 1 M305 P2 Hxx Lxx ; extruder 2
M502 M500
Re: fluctuating hot end temperature November 21, 2014 09:46AM |
Re: fluctuating hot end temperature November 21, 2014 10:01AM |
appjaws1
So just as a final check before I enter anything on my ormerod is the following correct for all firmware versions
M301 H0 S1.0 - bed heater, M301 H1 P1 S1 - extruder 1, M301 H2 P1 S1 - extruder 2
or use
M304 H0 S1.0 - bed heater, M304 H1 P1 S1 - extruder 1, M304 H2 P1 S1 - extruder 2
and
M305 P0 Hxx Lxx - bed heater, M305 P1 Hxx Lxx - extruder 1, M305 P2 Hxx Lxx - extruder 2
Paul
Re: fluctuating hot end temperature November 21, 2014 11:53AM |
Re: fluctuating hot end temperature November 21, 2014 01:04PM |
appjaws1
Thank you dc42 and zombiepantslol for your expertise and patience
I have repaired dc42's control board and wired a link so that the fan is on at all times.
I don't know how I change the P value to 1 instead of 10. I now have it set at 10 and the heater has much more power and reaches target with only a slight overshoot.
I have set up the H and L parameters using resistors and put the details in my config file.
However I still have a problem, if I or the gcode file starts up the external cooling then the hot end looses temperature and can not maintain the set temperature. Even with only 30% cooling the hot end struggles.
In the near past I could run the cooling at 100% and the hot end temperature would be maintained.
What else could be causing this loss of power, I have checked all crimps, connections and wiring, could the duet board be faulty? If so how can I check if that is indeed the problem?
Paul
Re: fluctuating hot end temperature November 21, 2014 02:06PM |
appjaws1
Paul
Re: fluctuating hot end temperature November 21, 2014 02:55PM |
dc42
appjaws1
Paul
Do you really have the S factor in the M301 or M304 commands for your nozzle heater(s) set to 0.6? If so, then your heaters will be limited to 60% of full power, which might explain why they struggle when the cooling fan is on.
Re: fluctuating hot end temperature November 21, 2014 04:09PM |
Re: fluctuating hot end temperature November 22, 2014 11:56AM |
Re: fluctuating hot end temperature November 22, 2014 06:09PM |
