Z axis leaning January 04, 2015 06:07AM |
Re: Z axis leaning January 04, 2015 07:53AM |
Re: Z axis leaning January 04, 2015 09:05AM |
Re: Z axis leaning January 04, 2015 10:21AM |
Re: Z axis leaning January 04, 2015 11:28AM |
Re: Z axis leaning January 04, 2015 12:54PM |
Re: Z axis leaning January 05, 2015 08:25AM |
rkc
Ok, I tinkered some more and I am now 99% sure that the problem is in the X arm not the Z pillar. I adjusted the bed to be at exactly 90 degrees to the pillar, measured along the X axis (may not be what I would want for printing, but much easier to set accurately for the purposes of this test). I then adjusted the z height until I could just fit a measuring block under the bar at the X=200 end. I had to raise Z a further 1.3mm before I could fit that same block under the bar at the X=0 end.
I repeated the test checking the height to the bottom of the acrylic X beam, and it's the same - i.e. it's the whole X beam that is tilted up not just the bar within it.
Is there a way to adjust this?
Richard
Re: Z axis leaning January 05, 2015 12:19PM |
dmould
The XZ plane is much easier to adjust, because that is taken care of by adjusting the bed so that it is exactly parallel to the X-axis ground rod. If you do that, the X-Z angle will be 90 degrees as far as the print is concerned even if the X and Z rods are not quite square in the XZ plane. The only effect of having those rods off-square will be to make the Z height of the print an insignificant bit smaller. So simply adjust the bed so that the nozzle touches the bed at the same height at X=0 and X=200.
Re: Z axis leaning January 06, 2015 07:14AM |
rkc
Very useful information - thanks!
I slackened off a few screws, checked with a set square, and retightened everything, and I am now in much better shape in general, though I have noticed (thanks to this and your other post in the other thread) that I have an issue with my Y rods not being parallel, so I'll have another go at getting that right next time I have a chance to tinker.
However I'm not sure I completely agree with you on this statement:
dmould
While I agree that you getting the bed and the X rod parallel is important (indeed, vital, or you won't be able to get your first layer to print properly), I think that if they are not perpendicular to Z then you will get a leaning model (unless corrected via M556), rather than just a shorter one. Imagine your X rod and bed both tilted up at 45 degrees - Z movements that were expected to be vertical would also have a substantial X component.
In my case, the slight angle between X and Z was corrected just by loosening the bolts attaching the X axis to the linear bearings, and retightening them after it had dropped a little under its own weight. It's now VERY close to perpendicular, and my test axes print reflects that. Certainly closer than it was.
Richard
Re: Z axis leaning January 06, 2015 04:43PM |
dmould
You are correct and I was indeed wrong - the X rod must be square to the Z rod. However the Z rod only has to be square to the bed in the XZ plane, not any other part of the printer, so any tilt in the X direction of the Z column is easiest fixed by adjusting the bed rather than the Z extrusion.
Dave
Re: Z axis leaning January 07, 2015 02:37AM |
rkc
..I think there is a bit of a design flaw on the Ormerod 2 (or I followed some instructions incorrectly) in that as assembled it is very liable to warp the Y axis rods to be non-parallel, since the extrusion is supported at just one end. I fixed mine by placing a 5mm packing piece under each end of the extrusion and then screwing the entire thing down to a piece of 18mm ply (and fastening the front rod down to the ply using cable ties)...
