Unable to get hot end up to temperature, suspect Duet is marginal. January 09, 2015 07:48PM |
Re: Unable to get hot end up to temperature, suspect Duet is marginal. January 09, 2015 07:51PM |
Re: Unable to get hot end up to temperature, suspect Duet is marginal. January 10, 2015 02:50AM |
Re: Unable to get hot end up to temperature, suspect Duet is marginal. January 10, 2015 04:39AM |
ErroneousBee
Commissioning my Ormerod 1, I have a couple of problems.
I'm trying to work out why my hot end won't respond. Applying a multimeter to the thermistor terminals at the board shows 139.4kOhm (Its about 18degC in here). If connect the board up and Connect to it with pronterface I get:
RepRapFirmware is up and running.
Printer is now online.
Temperature measurement fault on heater 1, T = -28.267216
Putting resitors across the pins and resetting then connecting pronterface to the board I get:a temperature readings
100k Ohm = 3.1 degC.
470 Ohm = 212.1 degC.
Should I persevere by heating the room before I continue, or should I get the better Duet board?
My next issue is I suspect the Y axis is somehow reversed. If I plug in the power supply, start pronterface, and press the blue Y Home button, it homes to the end away from the motor and end stop switch. Is this correct?
