Extrusionmotor nags me February 07, 2015 08:10AM |
; RepRapPro Ormerod ; Standard configuration G Codes <<<<<<< HEAD M111 S0; Debug off ======= >>>>>>> duet M550 POrmerod; Set the machine's name M551 Preprap; Set the password M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED; Set the MAC address M552 P192.168.178.55; Set the IP address M553 P255.255.255.0; Set netmask M554 P192.168.178.1; Set the gateway M555 P2; Emulate Marlin USB output T1 ; Select head 1 M92 E420.3783 ; Set extruder steps/mm G21 ; Work in mm G90 ; Absolute positioning M83 ; Extrusions relative M558 P1 ; Turn Z Probe on G31 Z1.8 P682 ; Set Z probe height and threshold M906 X800 Y800 Z800 E800 ; Motor currents (mA) M201 X1000 Y1000 Z15 E1000; acceleration tweaks for improved finish M203 X15000 Y15000 Z300 E3600; speed twe
Re: Extrusionmotor nags me February 07, 2015 09:17AM |
Re: Extrusionmotor nags me February 08, 2015 08:38AM |
Re: Extrusionmotor nags me February 08, 2015 09:35AM |
Re: Extrusionmotor nags me February 08, 2015 09:52AM |
Re: Extrusionmotor nags me February 08, 2015 11:04AM |
Re: Extrusionmotor nags me February 08, 2015 01:31PM |
Re: Extrusionmotor nags me February 08, 2015 03:24PM |
; Configuration file for RepRap Ormerod 1 ; RepRapPro Ltd ; ; Copy this file to config.g if you have an Ormerod 1. ; If you are updating a config.g that you already have you ; may wish to go through it and this file checking what you ; want to keep from your old file. ; M111 S0 ; Debug off M550 PMy RepRapPro Ormerod 1 ; Machine name (can be anything you like) M551 Preprap ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address M552 P192.168.1.14 ; IP address M553 P255.255.255.0 ; Netmask M554 P192.168.1.1 ; Gateway M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute corrdinates... M83 ; ...but relative extruder moves M906 X800 Y1000 Z800 E800 ; Set motor currents (mA) M92 E420 ; Set extruder steps per mm M558 P1 ; Use an unmodulated Z probe G31 Z0.8 P600 ; Set the probe height and threshold (deliberately too high to avoid bed crash on setup) M556 S78 X0 Y0 Z0 ; Put your axis compensation here M557 P0 X60 Y0 ; Four... M557 P1 X60 Y165 ; ...probe points... M557 P2 X222 Y165 ; ...for bed... M557 P3 X222 Y0 ; ...levelling M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min) M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute M563 P1 D0 H1 ; Define tool 1 G10 P1 S-273 R-273 ; Set tool 1 operating and standby temperatures
Re: Extrusionmotor nags me February 08, 2015 04:25PM |
redblunt
i just updated to 1.00g-dc42 HE still not working:
19:14:39 Attempt to set/report offsets and temperatures for non-existent tool: 1
19:13:55
19:13:45 Warning! Ormerod webserver is probably broken, power cycle/reset your Duet Board
the sd card is fine i tried sliding it in with a piece of paper, to enhance contact surfaces but still
nothing
Re: Extrusionmotor nags me February 09, 2015 04:57AM |
