Upgrading from 0.78t-alpha-dc42 to newest February 22, 2015 07:59AM |
; Configuration file for RepRap Ormerod ; RepRapPro Ltd ; M111 S0 ; Debug off M550 POrmerod ; Machine name (can be anything you like) M551 PPassword ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address M552 P192.168.0.180 ; IP address M553 P255.255.255.0 ; Netmask M554 P192.168.0.1 ; Gateway M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M906 X800 Y1000 Z800 E800 ; Set motor currents (mA) M563 P1 D0 H1 ; Define tool 1 G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures ;M563 P2 D1 H2 ; Define tool 2 (un-comment this for dual nozzle machines) ;G10 P2 S0 R0 ; Set tool 2 operating and standby temperatures (un-comment this for dual nozzle machines) M92 E424.2 ; Set extruder steps per mm M558 P1 ; Use an unmodulated Z probe or an intelligent Z probe G31 P500 Z0.60 ; Set the probe height and threshold (put your own values here) M305 P0 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction M305 P2 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction M557 P0 X70 Y20 ; Four... M557 P1 X70 Y180 ; ...probe points... M557 P2 X150 Y180 ; ...for bed... M557 P3 X180 Y20 ; ...levelling M557 P4 X141 Y82.5 ; 5th probe point for levelling (un-comment this if you are using a differential IR probe) ;M556 S78 X0.25 Y0.35 Z-0.15 ; Put your axis compensation here M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100
Re: Upgrading from 0.78t-alpha-dc42 to newest February 22, 2015 08:30AM |
